Help me guess this fluid. I dont think its oil
Old 08-05-2008, 03:30 PM
simpsons721's Avatar
The fluid is a dark rusty brown it is leaking from very slow but leaking
right under in the middle of the big crossmember at the position you place you jack
my car is going through violent squeling that just started and im trying to fix it also the leak is coming from the middle but more towards the passenger side
Old 08-05-2008, 03:35 PM
JasonWin's Avatar
a picture would really help, also I don't exactly understand your description...
Old 08-05-2008, 03:43 PM
Jay351's Avatar
What does it smell like?
It could be:
Motor oil (will smell like gas)
Power steering leak (should be ATF fluid)
Or your front differential (oil should smell pretty bad)
Old 08-05-2008, 03:55 PM
i guess it might be just oil
Old 08-05-2008, 04:17 PM
PCE91V64x4's Avatar
if it is associated with the squeal it could be power steering fluid.
How are your brakes? It could be the brake fluid that came in the truck new as well.
Old 08-05-2008, 04:28 PM
T-1000's Avatar
Low Power Steering fluid makes more of a groan than a squeal...Unless it's really low, then you can hear the pump chatter. My 4Runner drinks power steering fluid like a fish does water.
Old 08-05-2008, 04:30 PM
InternetRoadkill's Avatar
You sure it's not just dirty rusty water from inside the frame that's leaking out?
Old 08-05-2008, 04:55 PM
its like a scratchy squeal noise but it sounds like its coming from the drive shaft (middle of car)
Old 08-05-2008, 10:53 PM
Keith B.'s Avatar
FYI, the big crossmember under the trans/tfr is not a jack point.
Old 08-05-2008, 10:55 PM
CJM
CJM's Avatar
Rusty brown, kinda slick, smells burnt? Trans fluid, power steering is leaking or the trans.
Go get some brakleen and clean it all off then watch for where it comes from.
Old 08-05-2008, 11:29 PM
abecedarian's Avatar
under which crossmember? I've got a few under mine.
is the leaking fluid thick, thin, slick, sticky? ... have a sulfur smell?
and is it auto, manual? scratchy / squeal could be torque converter or clutch throwout / release bearing.
hard to diagnose sounds heard from keystrokes on someone else's computer.
Old 08-06-2008, 01:30 AM
toyminator2000's Avatar
hmmmmm. What does it taste like?
Old 08-06-2008, 02:56 AM
chicken
Old 08-06-2008, 06:33 AM
Matt16's Avatar
Probably automatic transmission fluid, BUT that could be from the PS pump or the tranny. Remember that Toyota uses automatic transmission fluid instead of PS fluid, so don't add the former. Is the PS reservoir low? The transmission cooler is near th rad I believe to that would be a logical place for the leak. I guess the first question should have been, Do you have a AT or 5spd?
Old 08-06-2008, 07:03 AM
dirtoyboy's Avatar
Originally Posted by abecedarian
chicken
squirrel
jasonty
41
12-23-2018 01:00 PM
calderp
Engine Swaps
08-16-2016 05:15 PM
Toyvana
07-29-2015 10:47 PM
calderp
07-27-2015 09:58 AM
Huntingtruckcletus
07-08-2015 05:26 PM
Quick Reply: Help me guess this fluid. I dont think its oil
