removing bed
Old Aug 3, 2008 | 06:05 PM
vermontoyota's Avatar
removing bed
Has anyone done a write up on removing the bed on one of our trucks?
Is it pretty simple?
Old Aug 3, 2008 | 06:22 PM
toyminator2000's Avatar
unscrew gas tank filler neck from bed. These screws will be tight. Remove all your wires from the tail lights and license plate light. un-bolt the 6 bolts holding the bed down. done. You can remove the plastic inner fender wells first if you want to.
Old Aug 3, 2008 | 07:07 PM
93rustedyota's Avatar
basicly whathe said but you may need to cut some bolts have fun
Old Aug 3, 2008 | 07:25 PM
Etype R's Avatar
If the bolts are not rusty, should be rather easy.... I had to cut every single bolt on my truck.
Old Aug 3, 2008 | 07:34 PM
forbiddenera's Avatar
hey.. nice to read this.. might need a new bed for mine as the is RUSTED
Old Aug 3, 2008 | 08:37 PM
Jay351's Avatar
FYI, there are 8 mounting bolts on the bed. Unbolt ( use penetrent lube to loosen them up before hand) these bolts, the gas filler neck and pull the taillight/licence plate wiring out.
2 guys can easily pick the bed up and pull it off..
Old Aug 3, 2008 | 09:16 PM
bruzer1123's Avatar
I would recommend taking the tailgate off prior to moving it as one piece...makes it a bit better to remove. I removed mine with a buddy and it wasn't too bad. The bolts on mine felt like they were stripped, but in reality they spin until an arm hits a solid piece and then they loosen up. Hit em with PB blaster for a couple days prior to removal and it should help.
Old Aug 3, 2008 | 10:50 PM
Sorry, you are correct. My bed is bobbed 14" and I eliminated one set of mount points.
Griff
93-98 T100s (Build-Up Section)
Sep 23, 2015 10:11 PM
58rennur4
Aug 4, 2015 08:49 AM
DrZero
18
Jul 24, 2015 11:31 PM
Backcountry411
Jul 24, 2015 08:06 AM
mickyd9990
Jul 6, 2015 09:01 AM
