compression check with a stuck spark plug?
Old Aug 5, 2008 | 06:39 PM
stanley's Avatar
Stupid question, but I'm trying to track down a problem with my 4Runner and I have one stuck spark plug. I don't feel like messing with the stuck plug anymore (It's less than 10K miles old anyway). Would I do any damage if I did a compression check on the other 5 cylinders?
Old Aug 5, 2008 | 06:56 PM
jd20phill's Avatar
you won't do any harm doing a compression test. Why do one though if you can't do it on all cylinders. How is your plug stuck? Crossthreaded or just seized up?
Old Aug 5, 2008 | 07:01 PM
Jay351's Avatar
I know your pain all to well. My number 6 plug is crossthreaded, has over 30k on it too....
Old Aug 5, 2008 | 07:04 PM
thook's Avatar
(Say, where are you at in Ark?)
No, you won't hurt anything, but you won't know anything about that cylinder, either.
Old Aug 5, 2008 | 07:07 PM
stanley's Avatar
Thanks, that what I thought about the compression check, I just wanted to make sure before I make things worse.
I think it's cross threaded. I can get the plug to turn a little bit if I use a breaker bar on it. I have rotated it less than a full turn in all my attempts. I figure at this point it's more worth my time to try a compression check then mess with a stubborn spark plug.
Edit- Mine is the #6 plug too- Is this a common problem? I think I remember using anti seize when I installed them last too.
Old Aug 5, 2008 | 07:11 PM
thook's Avatar
Well, if you've not created a leak at that plug, you're probably fine. I drove for a while with a crossthreaded plug. Know that you'll have to have that repaired, though, next time you change the plugs.
Old Aug 5, 2008 | 09:06 PM
jd20phill's Avatar
Well, im in LR until late August, and then its back up to Fayetteville. I take it your in NW Ark as well?
edit: I wouldn't mess with it if it was crossthreaded either, it could turn into a much larger job. Heli-coiling any spark plug holes on these v6's doesn't look like fun.
sandyota
Feb 4, 2021 11:16 AM
Eggslinger
Jun 8, 2019 03:32 PM
cars-guy
Jul 11, 2015 07:51 PM
smiley52
Jul 11, 2015 05:16 AM
88runnergomas
Jul 9, 2015 01:12 PM
