Clutch not popping back to full height.
Old Aug 7, 2008 | 06:56 PM
snelson's Avatar
92 - 3vze
Hey guys, I replaced the master and slave cylinders about 4 months ago, but ever since the clutch pedal won't quite pop back up the whole way to the top. I can shift pretty easy, but sometimes I have to pull the pedal to the top (the last inch or two) with my foot.
Is this a bleeding issue, or is there a little spring that makes the pedal pop up?
Should I bleed the clutch system again?
Thanks guys
Steve
Old Aug 7, 2008 | 07:40 PM
RobD's Avatar
I would start with bleeding it. Then I'd crawl under and make sure your slave cylinder is extending and retracting properly. It might be getting hung up on something.
Old Aug 7, 2008 | 09:06 PM
thook's Avatar
There is a return spring. Inspect that. Make sure your clutch pedal is adjusted properly, too.
http://personal.utulsa.edu/~nathan-b...sm/clutch.html
Old Aug 7, 2008 | 09:14 PM
CyMoN's Avatar
there should have been a spring that hooks up to the pin that holds the pedal to the MC.did you adjust the pedal out enough?
Old Aug 16, 2008 | 01:06 AM
spknucklehead's Avatar
i had the same problem theres a bracket that all the pedal mount on then that mounts to the fire wall mine had a crack in the mettal were the clutch pedal is i just welded it back and braced it because the nutt broke too
Jun 1, 2021 01:51 PM
Kalihi,HI
Jul 9, 2015 04:29 PM
colinmil
Jul 6, 2015 04:03 PM
wilbertd
Jul 6, 2015 07:39 AM
elwood73
Jul 5, 2015 07:07 AM
