if you gonna replace a u joint should you replace bothof em
Old Aug 7, 2008 | 02:23 PM
simpsons721's Avatar
Red face if you gonna replace a u joint should you replace bothof em
i drive a 2wd runner
im almost positive one of my u joints is bad should i replace both if im gonna do it just to make sure everything is fixed
Old Aug 7, 2008 | 02:26 PM
kramykram's Avatar
Am I drunk at 5:24 or did that hurt the head of any one else?
If it is 2WD you only have 1 Universal Joint.
OK wait, I guess it could be a 2pt drive shaft?
I need a beer.
Old Aug 7, 2008 | 03:19 PM
Jay351's Avatar
The rear shaft has more then 1 ujoint. Inspect all the others, if they are okay then don't replace them. Make sure you lube ALL the zerk fittings on the d-shaft, there are quite a few....
Old Aug 7, 2008 | 05:07 PM
abecedarian's Avatar
You don't have to replace all of them, but they are fairly inexpensive and having new ones all around won't hurt anything.
Old Aug 7, 2008 | 05:23 PM
JamesD's Avatar
You are correct but if the one that failed had 120k miles on it and you replace just the one, how long do you think the other one is going to last? Factory Toyota greaseable joints last a lifetime if you lube them constantly. The reason it probably failed was due to the lack of maintenance or it was a non-greaseable type.
James
icentropy
Sep 16, 2020 02:47 PM
Doug4320
Mar 24, 2018 10:11 PM
Sep 4, 2015 09:27 AM
Kalihi,HI
Jul 9, 2015 04:29 PM
ptb12
Jul 5, 2015 01:49 PM
