Very wierd pulley problem. Please help.
Old Aug 4, 2008 | 06:28 AM
ThomasTedder's Avatar
There are those three pulleys on the crank that turn various accessories. The inside one that turns the alternator and the fan is not moving. It is just sitting there still while the other two are spinning.
Old Aug 4, 2008 | 06:31 AM
DeathCougar's Avatar
You need a new balancer. The outer pulley has seperated from the inner balancer, via the rubber between them.
Old Aug 4, 2008 | 06:35 AM
harmonic balancer? is that all one piece with the pulleys?
Old Aug 4, 2008 | 06:48 AM
I just looked up a harmonic balancer and it has two pulleys.
Do you know which belt the third pulley drives? And does the third one bolt up to the harmonic balancer or something?
Old Aug 4, 2008 | 08:07 AM
The harmonic balancer has two pulleys, each individually attached via rubber. the third outer pulley (power steering) is bolted onto the balancer.
Again...You need a new harmonic balancer.
Old Aug 4, 2008 | 09:54 AM
Thanks DeathCougar.
Old Aug 4, 2008 | 03:34 PM
84sr5yoty's Avatar
Yep, you need a new balancer.
Damper Dudes sell a new one for a reasonable price.
http://www.damperdudes.net//product_...roducts_id=195
Blamalam
Mar 12, 2022 07:34 AM
Scatpac
May 25, 2017 06:47 AM
Dennisx2
Aug 10, 2015 06:48 AM
Dennisx2
Aug 4, 2015 01:26 PM
PlayAwhile
Jul 20, 2015 11:36 AM
