PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 [35] 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Zuk Mod Question on '92 2WD Pickup;Only have U-Bolts on Top of Springs
  2. Some 10w30 in manual tranny ok?
  3. 1985 trx cab bed swap
  4. Timing belt tensioner
  5. Knock Sensor rewiring question
  6. 4.88 or 5.29 on a stick???
  7. 22RE stick to automatic conversion??
  8. Stuck Hood Latch
  9. Clutch problems, need help asap!
  10. Blower only working on low setting - not resistor
  11. 1995 4 Runner with low speed sputter
  12. 1989 toyota pickup auto transmission
  13. How much lift do I have
  14. Blower not blowing so hard
  15. How do I unstick a valve
  16. Bumper compatability
  17. Clutch nightmare
  18. rear diff/t-case??? LEAK
  19. 3VZE Clatter at 2000-3000 RPM
  20. 4runner smoking
  21. GL-5 safe in t-case? m/t
  22. Scored NOS Downey IFS Truss
  23. Does my 1993 Toyota 4 runner have a cabin air filter
  24. On a budget and need a 22re head
  25. #2 cylinder dead 22re
  26. 1995 4Runner EGR and Failed Texas Emissions
  27. Bad Grounding Issue??? HELP 89 Pickup
  28. Heater blower in-op, not the usual suspects
  29. Found a mysterious circuit board in my 4runner
  30. Clutch issue
  31. Play in pinion....should I try to fix myself?
  32. 88 4runner rear differential leak
  33. 90 model 4 runner want start
  34. best parts?
  35. Bought me a 90 ext Cab 4x4
  36. 94 topper (bed cap)
  37. door locked and rods inside are loose...how to unlock/open door?
  38. Air conditioner bracket removal.
  39. 92 22RE Head Work
  40. new 22re distibutor cap/rotor
  41. need help with part #
  42. Recommended 5 speed transmission fluid
  43. 3vze TPS adjustment/injector replacement woes
  44. beadlocks and backspacing
  45. Middle Console Comparison: First Gen to Second Gen?
  46. What does the EGR vacuum modulator DO on the 3vze?
  47. '89 2WD Pickup Suspension Advice
  48. 4WD 1995 4Runner
  49. Seat Covers
  50. Replacement mirrors for vent window trucks?
  51. Shock Options
  52. HELP MY 87_4×4 sr5 pickup. Won't start
  53. Fuses, Relays, Fuse Blocks ID and Locations - 1986 4Runner / Pickup
  54. Tire Upsize
  55. Tire Upsize
  56. How to install Tachometer for 84 Toyota Pickup Camper 22R 4cyl
  57. Lift removal/ identification?
  58. Need engine suggestions
  59. Crankshaft/Flywheel balancing
  60. no spark
  61. How to install Tachometer for 84 Toyota Pickup Camper 22R 4cyl
  62. none of the power windows work
  63. Driver side fuel door - Which model it is?
  64. 1999 4Runner Limited Worth fixing or not??
  65. 1994 Automatic 4x4 Trans should fit 1993 Auto 4x4 4runner?
  66. My A/C Tensioner Pulley Walked Off!
  67. '89 4runner: Power Steering Belt Too Long
  68. Newbie with shifter question
  69. Looking for part in pic
  70. Slight idle surge after installing and adjusting brand new TPS
  71. Crunching when turing but only when stopped and rumble strip sound 55mph plus
  72. wrench size needed for Toyota P/N 31482
  73. need to know how to pull codes and set timing for 86 runner
  74. OEM Replica Cruise Control
  75. Gas Gauge/fuel light malfunction
  76. Can you reuse donor cross member and shock tower for SAS?
  77. Drive shaft fell out on the highway, need some advice
  78. 3vze Still overheating after replacing thermostat, and water pump
  79. Overheating after valve clearance adjustment
  80. 1991 4runner transmission lines
  81. 22RE Fuel Mileage Nightmare
  82. Rebuild won't start (yup, another one)
  83. Stumble & Check Engine Light, 91 22RE
  84. I need to ask
  85. Rough start with brief "check engine" light
  86. Water pump impeller size riddles...
  87. Bad smell (petting zoo) from vents
  88. flat bed
  89. 1994 Toyota 4Runner bucking and fuel cutout
  90. FIPG on cam seals?
  91. new engine need help
  92. 3VZE Fan Shroud
  93. FOUND: Source for Fuel suction lines tank
  94. Ac idle up kit 89 pickup 22re
  95. Noise on 93 toyota pickup
  96. Front End Issues & Wheel Bearings: Timken or Koyo?
  97. Speedometer & odometer + oil pressure gauges stopped
  98. AC tensioner pulley missing
  99. AC Evaporator Access???
  100. 91 Toyota 4runner 3.0 oil pump
  101. 95 4runner won't start
  102. Center Cap help
  103. Wheel fitment
  104. 1995 T100 - White steam billowing from exhaust
  105. Brand new clutch kit and flywheel. Clutch pedal now engages very high.
  106. Lift Kit?
  107. Missing "gremlin" 1990 3VZE is misfiring
  108. New Owner: '88 Pickup
  109. turn signal problems
  110. engine not starting
  111. 1986 Toyota Pickup 4x4 22rte
  112. CAR RADIO no power
  113. Power capability difference: rear defrost switch vs. deck lamp switch
  114. Front Drive Shaft (propeller) Yoke/Flange
  115. joe
  116. joe
  117. 1986 Toyota Pickup 4x4 22rte Auto to manual
  118. Replaced power window regulator on my 86
  119. Timing is not lining tdc on 22re half chain link off
  120. Timing is not lining tdc on 22re half chain link off
  121. New to YotaTech - kinda
  122. Another 3.4 swap
  123. HELP pls, can't find tie rod to heim adapter for my pickup
  124. 1992 SR5 3.4 swap
  125. 89 22R Idles Great/Sputters/Dies under Accel.
  126. 3.0 won't idle
  127. What's needed 3.4 swap?
  128. 95 Toyota pick up 2we timing issue half tooth off?
  129. '93 A/C compressor replace (r134a converted)
  130. Morning Start/Hard Cold Start/Fuel Pressure?
  131. Odometer reset?
  132. Fuel rail spraying fuel
  133. Required lift
  134. 86 4Runner SR5 Turbo Fuel sender issue
  135. 88 4runner experiencing odd head issue
  136. Having difficulty starting issues, HELP???
  137. Code 21 on 1993 toyota pick up (22re)
  138. Bad vibrations
  139. 3.0 3VZE HG Repair Mileage-Toyota Performed
  140. Installing weber 32/36 cal smog legal on 87 yota 22r
  141. VSS part number
  142. 94 3.0 runner limited build.
  143. Power loss, vibration, oil leak.
  144. 3.0 low power in closed loop
  145. 94 pickup wiring harness
  146. 91 22re o2 sensor wiring and no place for o2 sensor
  147. Engine
  148. Dipstick question on newly aquired truck
  149. 3VZE Electrical Wiring 1989 4Runner
  150. Looking for new shock for my truck
  151. Knock sensor loom connector
  152. Control Arm Creak
  153. Intermittent fuel pump operation/failure
  154. stereo with GPS
  155. 91 Transmission Problem
  156. Fender Flare Hole Fix
  157. Crankshaft oil galley plugs
  158. Shocks recommendation for '82 Toyota Odyssey?
  159. Help!! 5speed swap fail!
  160. No trans lockup A340E
  161. '88 Pickup CSI Switch
  162. Interior swap - Should I replace heater core?
  163. 86' A340H Shifts out of L
  164. Light Bulbs in overdrive switch
  165. 1st gen 4Runner Ashtray Cup Holder?
  166. Bracket holding auto transmission cooler lines
  167. My heartache stories
  168. Which auto trans lines to radiator are which?
  169. Todays Radiators?
  170. 87 4runner
  171. What is the proper rim size and backspacing for a 1990 4WD 4 Runner?
  172. 3-Point Seatbelt for Middle Bench Seat
  173. 93 Pickup, 22re #3 low func or not working
  174. 1992 Auto Trans into 1993 4runner
  175. Alternator belt keeps slipping off my 93 4Runner u
  176. Alternator belt keeps slipping off my 93 4Runner u
  177. 22-re low oil pressure
  178. highway speed problem- 87 4runner lack of power up to 60
  179. Fan grenade
  180. 1992 Toyota pickup 4WD 3.0 V6: Pulls left after letting go of steering wheel
  181. Small interior
  182. 22R Carb - Repair or Replace - What Would You Do?
  183. Bumper nuts & bolts
  184. Charchee's 89 Runner Windshield and Rust Repair
  185. can't find obscure VF1A Rear output shaft seal
  186. Ifs spindle lift
  187. Accerleration Noise
  188. Rebuilding rear differential. 4x4
  189. Truck won't start
  190. tail light fuse
  191. V6 3.0 timing belt change: how much to replace at ~100k miles?
  192. Broken BVSV on 22re
  193. Recent head gasket change; now transmission issue
  194. Freshly rebuilt 22r. Turns over but won't start.
  195. Who makes a good stock style replacement carburetor?
  196. Horsepower gain on 3.0 from CAT delete?
  197. Cruise Control on a 22R
  198. What is the actual number of miles on 1992 toyota pickup 22re
  199. 1991 Toyota Pickup AC Squeal
  200. New here!! Looking for help!!
  201. 92 pickup timing issue
  202. Efi relay noisy,non start engine
  203. how much for a parts truck?
  204. Turn Signal On, Causes Stereo Off
  205. Wiring up oil and temp gauges
  206. 92 pickup timing issue
  207. Headgasket job quicky?
  208. 4Runner mirrors on pickup
  209. Where does my dashpot onnect to?
  210. Getting there.............
  211. 86' DLX Xtra-cab 22r 4WD
  212. What's this connector for?
  213. Water pump question
  214. 1993 V6 4runner with auto A340H trans will not shift past 2nd gear
  215. 22R-E is Ear Piercingly Loud from 1K-2K RPM - Normal?
  216. Is my intake manifold leaking?
  217. I'm "stuck" with a problem
  218. Blew 2 alternators in two weeks charge light came on less then 12 hours after install
  219. Serious steering stop rubbing/wear
  220. '94 pickup engine and trans replacement
  221. '87 PS Pump Leak Somewhere
  222. '87 Digital Dash Fuel Gauge Not Working
  223. Another Idle/dies when warm 22re
  224. TCpickup's wheeling checklist
  225. T4R 88 first gen door switch problem
  226. Johnny McDoofus strikes again (electrical issue)
  227. Popping sound after timing belt
  228. Rough and low idle after backfire
  229. I'm stumped,
  230. 1987 fsm
  231. 1991 4Runner - how to fix rear key tailgate window electrical
  232. 1989 22RE Pickup, Multiple CEL codes and hesitation
  233. Transfer Case Pan Gasket (with A340H auto trans)
  234. A340H Transmission Filter/Screen change
  235. Replacing Timing Chain guide through Valve Cover
  236. tailgate latch repair
  237. 1990 toyota pickup 22re won't start if left sitting 1-2 hours after driving
  238. Gear oil for manual transmissions
  239. Super sluggish when cold
  240. Carb tuning and tweaking.
  241. Valve cover gasket 22re
  242. 1st first gen 4runner
  243. 94 4Runner Fuel door
  244. OK, TOYOTA tech is stumped, start quizing me.....
  245. NEED Torque Specs - Leaf Spring U-Bolts
  246. VF1 terminal voltage and VAFM adjustment
  247. Pinion length difference
  248. Is this caliper piston too pitted?
  249. Where to find 5.29s for my 86 pickup?
  250. Leaking oil Batman!
