95 Toyota pick up 2we timing issue half tooth off?
Old Apr 28, 2017 | 07:12 PM
Yota headach's Avatar
95 Toyota pickup 2wd timing issue half tooth off?
Okay here's the deal I've had the biggest headache with this truck I had the mains knocking in the truck well it finally went down my friend had the same motor 22re and we thought it was good well I pulled the oil pan it had a piece of the timing guide in it. Long story short changed basically everything. Well a port hole was clogged so I had water blow back and thought it was a head gasket so I pulled it and replaced it and found the problem fixed it and was going to replace intake well another fail cracked it bc of a bracket so pulled the motor again well I got it out of time when I pulled the head so then thought I put it in time. NOPE WRONG AGAIN okay now when I place crank on Tdc then the cam is off a little. Thought I could turn crank but when I put them both tdc then my chain want go on but all dots lined up and the chain links marked are in the right place I'm still off. I rotated to cam to Tdc with the cam line and my crank is off about 1/8 inch past 0. WHAT CAN I DO? HELPPPPPPP PLEASE PLEASE PLEASE PLEASE
