FIPG on cam seals?
Old May 3, 2017 | 08:20 PM
128keaton's Avatar
FIPG on cam seals?
I think I have an oil leak coming from my cam seals, won't know until this weekend, but I have a leak that comes from the upper front. Not sure where else it COULD come from, other than the caps on the front.
I know you put FIPG around the back seals, but what about the ring?
Thanks!
Old May 3, 2017 | 08:43 PM
scope103's Avatar
For what it is worth, Toyota doesn't recommend FIPG or any other sealant on either the back seals or the cam seals. http://web.archive.org/web/201208130...68cylinder.pdf
The seals have an elastomeric ("rubber") edge where it meets the cam bearing cap, so that makes sense to me.
Old May 3, 2017 | 08:45 PM
128keaton's Avatar
I thought I remembered that correctly. I guess the only other spot would be those retaining caps there. Thanks!
Anywhere else I should look?
Old May 4, 2017 | 05:04 AM
scope103's Avatar
The only "trick" of which I am aware is the installation of the valve covers. The manual shows sealant on four spots under the gasket (I use oil resistant RTV, but if you're really fast, FIPG is certainly a good product). Essentially, where the gasket makes a right angle turn at the cam bearing caps. Skip this at your peril!
RTV doesn't stick really well to oil, so I've gotten much better results when I make sure the RTV-metal is sparkling clean. I just use paint thinner, but brake cleaner might be easier to use.
PS: is that a picture of your engine? I know it's just a matter of time and elbow grease, but cleaned up like that it is a sight to behold.
Old May 4, 2017 | 07:28 AM
CRSHR's Avatar
FPIG is not necessary. What I do is use some transmission Assembly grease and put a thin coat on the outside of the seal(any seal) to help it slide in. If im driving the seal in I will pack the inside of the seal as a precaution to keep the spring from popping out. You probably already know this but they are more easily installed with the cam cap off.
Old May 4, 2017 | 04:36 PM
128keaton's Avatar
Oh yes, haha they were really hard to get on with the cap off, not sure how I could get it done with the cap on.
