90 model 4 runner want start
Old May 14, 2017 | 05:45 PM
soldier446's Avatar
hello my yota recently started acting up and want start upon checking I realized it not getting fuel as pump is not coming on after further checking I found out my c.o.r.is clicking when I engage my stater but have also found out the air gate in my finler box is not opening can you give my ideas or sugestions on what to do and check now as I'm lost
Old May 14, 2017 | 05:53 PM
dropzone's Avatar
Fossilized
22RE or 3.0?
What is a finler box?
Old May 14, 2017 | 06:10 PM
soldier446's Avatar
my typing skills are bad sorry I meant the air filter box and its a 22 re
Old May 15, 2017 | 02:17 PM
CRSHR's Avatar
Do you have power and ground at the fuel pump connector? You can get to it under the passenger rear seat. A test light is cheap and a great tool to have.
Old May 20, 2017 | 08:08 AM
soldier446's Avatar
there is no signal at all going to fuel pump at this time even when I turn the enginw over my cor is clicking when I try to start it but I'm not sure that my fuel pump relay is can this relay keep that air gate from opening as well as not engage the pump
Old May 20, 2017 | 08:43 AM
scope103's Avatar
Breathe, soldier446, breathe!
Okay, your lack of punctuation and idiosyncratic spelling makes it sound like you're just blurting out something (something that makes little sense). Take your time, use punctuation and full sentences, and try to spell what you mean. If the answers you get are just guesses, what good does that do you?
If you suspect a problem with the VAF-COR circuit, jumper FP to B+ in the diagnostic connector. With key-on, you should be able to hear the pump. If you can then start it, you've narrowed down the problem significantly (and this doesn't involve pulling any seats). Then, pull the jumper, with key-on use your finger to push the flap in the VAF. Can you hear the COR close? If not, the switch in the VAF is bad, or the COR is bad (or some wiring is bad). If you can hear the relay, put your multimeter on FP to ground, and check for voltage when you push the flap. You should go from 0 to 12v when the COR closes.
Old May 20, 2017 | 08:47 AM
soldier446's Avatar
is the air gate over the airfilter what you are calling the vaf?
RAD4Runner
Mar 29, 2024 06:30 PM
beardedclam
Diesel Swaps
Feb 14, 2018 05:12 PM
the1998-sr5
26
May 20, 2017 07:19 AM
thezentree
10
May 8, 2017 09:45 PM
orbital02
Mar 12, 2017 07:38 AM
