Stuck Hood Latch
Old May 19, 2017 | 02:34 PM
jalopytech's Avatar
Stuck Hood Latch
Read several posts regarding inoperative hood latch mechanism I recently encountered a problem while on a 2500 mile trip in my 89 after attempting the 2 man release to no avail and WD40. I gave up and didn't check under the hood the last 750 miles of the trip. When I decided to fix the problem with the latch I found that a mystery bolt had fallen into the mechanism causing it to jam. I was able to gently pry the plastic grill enough to get a 1/4" drive extension and 10MM socket onto the 3 bolts holding the latch in place. After removing the bolts the whole mechanism came out and the problem was corrected by just removing the bolt. I also removed the shield that keeps one from accessing the latch so that if the cable should ever fail I could access the lever with some sort of tool to open, hope this help anyone that thinks the hood or latch must be destroyed to force open.
Old May 19, 2017 | 03:24 PM
ALFILREY's Avatar
Thank you, a little trick.
