Power capability difference: rear defrost switch vs. deck lamp switch
Old Apr 30, 2017 | 05:42 PM
I8URSVT's Avatar
What is the amp capability difference between the rear defrost switch and the deck lamp switch? I believe the deck lamp switch has 2 wires, while the rear defrost switch has 4 wires. Im trying to repurpose these switches for extra lights and aux stuff and wanting the era-correct switches (which is why im usibg tgese rather than buying new switches). Any info you have would be much appreciated
Old Apr 30, 2017 | 05:49 PM
millball's Avatar
There is probably no difference in the switches current capacity. The additional wires for one probably go to a pilot indicator bulb, or something similar. The deck lamp might be directly wired because the current it uses is small, while the defroster is likely to go through a relay.
It is always wise to use relay switching when the current is more than a couple amps.
