What's this connector for?
Old Apr 19, 2017 | 12:15 AM
fishy_mcfish's Avatar
I found it laying down by the control arm on the passenger side. As best I can tell the wire runs up above the ac compressor. This is on a 92 4x4 truck with the v6
Old Apr 19, 2017 | 12:39 AM
Terrys87's Avatar
That is a 92 and a V6 truck so is different then what I am use to seeing. I am thinking it goes to a sensor on the transfer case but could be wrong. On the earlier models I see it disconnected numerous times as it is easily snagged on brush or similar obstacles.
Old Apr 19, 2017 | 04:48 AM
rustypigeon's Avatar
What color is the wire?
Old Apr 19, 2017 | 06:53 AM
az4x4runner's Avatar
Looks like the AC compressor clutch wire.
Old Apr 19, 2017 | 07:12 AM
i believe it was black.
Old Apr 19, 2017 | 07:13 AM
i was thinking it went to the ac compressor but I couldn't tell. The truck has had a massive power steering leak for awhile so the compressor is totally caked in grease and grime :/
Old Apr 19, 2017 | 07:21 AM
Leaking at the pump? My 4Runner had a massive PS leak a couple years after I got it, someone ran power steering fluid in it instead of ATF. Not good for the seals.It's easy enough to rebuild the stock pump, or get a decent replacement from Napa. Probably been 10 years now without a drop.
Anyway, that wire should be powered if you turn on the AC button (engine on), assuming everything else in the system is connected and functional.
EDIT: The wire coming out of the harness should be black with a white stripe.
Old Apr 19, 2017 | 11:08 AM
yes it is black with a white stripe. And now that you mention it, the green light doesn't illuminate anymore when I push the ac button in. Now I just have to try and figure out where it connects.
Old Apr 19, 2017 | 11:19 AM
If you are getting voltage out of the harness with the button pressed, it could be as simple as the LED in the switch. I have had AC issues with Toyota's "AC Amplifier" which is behind the glove box, it controls all things AC (clutch) based on signal from temp sensor (on 4WD trucks), pressure switch, ignition signal, thermistor, etc. I don't know how common it is for them to go out, but it happened to me.
