I'm "stuck" with a problem
Old Apr 18, 2017 | 07:05 AM
Old Yota Racer's Avatar
Im replacing the t/stat on my 1990 PKP, and I removed the t/stat with no problems, but the gasket, or remains of it are stuck to the housing on the block. none of it was stuck to the water neck, and some of it peeled right off. Whats a good solvent to get the hard pieces of the gasket off the housing. I tried digging it out with needle nose and also tried scraping it out, but dont want to damage the housing. Any suggestions?
Old Apr 18, 2017 | 07:25 AM
az4x4runner's Avatar
I use brake cleaner. Mostly after picking the old gasket material off, but it might help loosen it up.
Old Apr 18, 2017 | 02:16 PM
wyoming9's Avatar
Red face
I use those Roloc Discs for Aluminum on the 90 Degree die grinder
Great for removing old stuck gaskets
Old Apr 19, 2017 | 05:14 PM
Terrys87's Avatar
I use a razor blade as a scraper.
Old Apr 20, 2017 | 03:09 PM
space-junk's Avatar
wire bbq brush and elbow grease.
Old Apr 20, 2017 | 03:22 PM
scope103's Avatar
Remember that a razor blade (BBQ brush, and even a Roloc Disc) is much harder than aluminum. So you can do real damage if you go nuts.
So don't go nuts! Keep the razor blade at a low angle. Use a light touch with the brush or Roloc. Me, I like using a non-woven scrubber ("Greenie" or Scotch-Brite pad) to finish it off. But even a Scotch-Brite can go through aluminum if you work it enough.
