- Need Pro Welding help
- YotaChat, TAKE A PEEK
- OME Springs installed
- valve adjustments to my 3.0
- '93 4 runner front tranny question
- ECU Interchange
- did my reseach but still have a few tire q's
- How much lift do I have?
- 4wd wont engage
- Towed a 3k pound boat/trailer over Stevens (WA). Results:
- torsions
- What T-case in a 86 Turbo?
- question about rust repair and prevention
- "TPS' sensor
- Can you say "Hydro-lock?"
- Stalling Out
- advice needed on finding a manual 3.4l vehicle for a swap...
- head gasket replacement
- Replace Turbo Tranny w/ Non-turbo tranny
- ID this part and why it is leaking anti-freeze please.
- Bent steering relay rod?
- good thing the cam didnt break!!!
- 3.0 replacement done. 88 4runner
- Help, 5 speed stuck in reverse
- 22RE Rebuild Options
- Master Rebuild Kit for 22RE? Recomendations?
- TEC Turbo Kit installed - 86 Pickup RTEC
- Pricing advice on a 93 P/up
- Picked up my new toy (yes, pun intended) yesterday
- alternator help
- Fuel Injectors 92 4R
- 2 gen. front door differences?
- Tokico shocks...anyone have experience...
- part number for 92 v6 xcab front rotors?
- Painting 4runner
- Locked up 3VZE - other problems?
- Buying a header but confused...
- Cruise Control
- Is it possible to change from power windows to manual?
- Is my 4runner using that much oil?
- 22RET w/ Aftermarket Cam
- Rear Diff Leaking...
- toyota motor swap
- Rear End "Clunk"
- 93 3vz intermittent sputter (hesistation)
- problems with the fuse box
- TPS ??'s Cause engine to run rich?
- Fine Thread Metric Zerk
- another question on 33s....
- What's your range on the low-fuel light?
- 3.0 Header Gaskets?
- Have you ever taken off your steering wheel?
- Spindle Question
- 3.0 excessive oil consumption!
- Kill Switch ideas
- 88 22r carb questions
- ac problems
- Any danger in tightening TV cable past spec?
- tinkering noise when turning off
- no oil pressure
- brake lines
- is the celica or mr2 turbo manifold SAME as the 22re?
- my 95 runner photos
- where to get bilstein shock boots??
- engine drops rpm when oil cap is removed while idling..
- Transmission Temperature Controled?
- Brake issues
- white smoke AFTER headgasket repair
- 94 4runner & Truck front doors the same?
- 1986 4Runner: stock rear step bumper
- Toyota Brush Guard
- o/d light blinking cleared?
- How often do water pumps go?
- Must all 4 tires be of the same brand???
- cross linked air shocks
- how much for a brake job?
- Brake light is on
- Manual Transmission Front Seal Leak. Will Leak Stop Work?
- ac problems
- 1994 4Runner Clicking Noise
- crankshaft seal
- 22RE Check engine light code 24....??
- 2nd Gen 4runner rear suspension.
- I'm blowing black smoke and going through gas like crazy!
- how to lubricate the rear window assembly
- Buying advice: '94 Toyota 4x4 4cyl
- 3.0 engine change is almost complete
- mass air flow sensor
- About to start repairing rust on my 95. Have a few questions.
- Third Members???
- Project Snowball: RE: drum backing plates?
- Water Comming Out From Under Dash
- bad A/C compressor?
- disconnecting front axles
- Speedo Corrector Kit installed
- Knock Sensor- Help needed fast!
- 10w-40 oil quites my 22RE
- 17" rims vs 15" rims
- toyota service manual issues
- vibration- transfer case-loose rear companion flange?
- Getting my new exhaust done this week and need advice!!
- Devilish hum in the engine
- Paint ideas?
- Oil pressure question
- Transmission / Starter Problems???
- a/c blowing hot air while at idle
- E3 sparkplugs?
- new member here
- speedometer adjustment question
- O2 Sensor Permanently Rusted On!
- Trailer hitch bar
- Over Drive
- Exhaust?
- 91 Bumpers and dashes interchange with what years
- 93 ext. cab rear shocks.
- Can't keep the coolant down
- Body lift or suspension lift....
- first trip. rub issues
- brakes
- help with gauges
- motor replacement question
- 95 3.0 4Runner EGR Problem. Attension 3VZE experts, Tried everything!!!
- stupid clear coat
- 4.88's and 35's
- How to tell if rear leaf springs are worn
- 87 4runner AC condenser question
- swaybar link after balljoint spacer
- Factory Toyota Part - What is it?
- once again, front axle stubs won't pull out!
- Will 02 Tacoma rear shocks fit on my 4runner?
- Sway bar end broken off
- First impressions on Vortex Muffler
- 22R carb options
- guaging intrest for 2 possible group buys
- Anybody install an MSD/Jacobs multi-spark system?
- Brake Master Cylinder question
- Best way to get rid of my "desert pinstriping"?
- Electrical problems on my 88 Toy
- head gasket.. i'm stumped
- Need Help - Oil Leak 1994 V6
- New Twist On My Old Tail Lights(pics...)
- ifs parts
- 4x4 won't engage and speedometer wiggles
- manual hub not fully releasing CV axle
- Packing Bearrings
- E-brake light fluke
- Stereo cutting off
- Brake Line Leak
- Rear Braking Problem & LSPV
- Transmission and Speedometer problems with a 92 Runner
- red vacuum tubes
- Factory winch and grill guard?
- Manual Locking Hub Problem
- sagging, rough riding rear?
- Brake Question
- clutch, manual hub, blinker, etc problems
- Help with trans and diff fluid change
- 4x4 wont engage
- Help with timing belt change
- When CEL is on the engine is lugging
- Changing my e brake cable...
- Bone Yard
- Theory- 3.0/autos will overheat with an electric fan...
- 87 2WD A43D OverDrive Solenoid Location
- New to YotaTech and thought I'd share my rigs
- What model trans is this?
- 3.0 ignition coil? has anyone replaced or upgraded theirs?
- 1990 and 1991 4Runners, I need your help
- Just get the sag out
- 22r or 22rec head
- spark plug problems with 3.0 engine.
- trans tcase mount
- Spare tire moved from underneath to rear
- Need wiring diagram for an 88 4runner back window?
- Strange Problem 22re Idles but....
- Last year of the 22RE in 4X4??
- 4WD problem Need some ideas
- my crappy day and future thoughts
- Reverse lights inop!
- Torsion bar lift
- Lights Out
- my rebuilt engine was rebuilt by gorillas
- 2wd rear axle vs. 4wd rear axle (newbie warning)
- Misalignment Driveshaft?
- 3" body lift on a automatic 4runner
- R150F Transmission overhaul prices
- What exactly is the towing package for our trucks?
- pinging with correct timing and 91+ octane...
- lc engineering lean/rich controller
- Well< i have some LC headers coming my way!!
- 91 4X4 Clutch Vibration
- need cab corners!
- E-Brake Light Glowing
- clutch possibly going out?
- 3.4L swap more q?
- Cabin Filter?
- CV axle outer retaining clip issue
- Trade 95 runner 4" procomp lift & 33" tires
- 95 4runner turns over but will not start.
- Changed Timing Belt now Idle is low(400RPMS)
- might have found a good deal on 85 sr5 seats, same as '89-95??
- Scrap the 3.0 or not?
- TTY Headbolts diffrent
- Head bolts
- BAD REAR window BAD Window
- 1992 4runner won't shift
- Blowing both directional signal and hazard fuses
- Still sputtering
- Auto-Tranny Shifting hard into Drive
- Help Needed, 88 4runner rear window
- Help with electrical problem
- 7" and 37's?
- A/C on a V6 which is Hi, Lo?
- Part # for oil seal behind hub on '93 4R
- Truck is fixed.
- Catback Exhaust size....3.0
- New fuel pump won't work.
- How to remove intake from 22re!?
- Can't remove CV AXLE nuts
- need injector help 86 22re
- separating front rotor from axle hub.
- a/c stops cooling at times
- My 91 4runner, 4x4 issues
- Anybody out there ever change an AC compressor?
- '91 4Runner
- Serious Drivetrain problem
- Another Cooling Fan Question
- Some pics of my ride
- SASed tan 2nd gen - who are you?!
- A/C rough idle
- a/c troubleshoot
- Ironman Suspension???
- Swapping 22RE's - Computer issues?
- excessive heat near the center console
- Wobbly CV Joint
- power window wiring help!
- Code 25 and rough idle
- Transmission types?
- Hub Question
- 22re Engine harness and knock sensor problems
- Need help with strange underhood nosie
- Who Has NOT Had HG Issues With 3VZE?
- Complete Brake Upgade and more...
- Low Fuel (Dummy light) is out
- Help Need 88 4runner motor mounts
- seal over rear plug on cam?
- help my toyota burns coolant
- Am I stupid for choosing current 94 3.0l over 96 3.4l???
- Rear Main Seal Leaking...Getting Worst
- Need help on steering spindle replacement- unanswered questions
