3.0 ignition coil? has anyone replaced or upgraded theirs?
Hi guys, I知 getting ready to install new NGK blue wires, Toyota cap and rotor and try my luck with a set of NGK iridium plugs in my old 3.0 My truck has been getting harder to start and I知 wondering if its related to the ignition system or to the fuel I致e been buying "Sheetz 89". I was just wondering how long the coil should go before being replaced... let me back that up some, can you replace these coils with say a Flame Thrower 6cyl coil? or do they need to be the stock coil or would it not make a difference????
I have an "upgraded" jacobs coil that replaces the stock coil. I bought it of ebay with an ignitor for $3.00 so I couldn't pass it up as a spare. it runs exactly the same as my stock coil/ignitor assembly. if your looking for more power, the stock ignition is just fine, work on the heads and exhaust first.
good luck
good luck
good luck
good luck
So it definitely made a difference for you?
My stock coil is still in the vehicle hooked up as a spare (firing into a big resistor). I felt most of my gains up on top just as the dyno shows. Plug gap didn't seem to make much difference for me but now I run cheap auto-lites with hard electrodes with better results than expensive plugs on weak ignitions. If I ever make it to a dyno I will compare the 2 ignitions since its only a few mins to convert back to the other.
FWIW... I bought the full system because that's where the gains are. I don't think a simple coil will do anything for you. I bought the ICE system
ah ok honestly when it comes to those ignition systems Im a bit confused. there is the pro street, the ICE, the milage miser, repeaters and all kindsa stuff. And the jacob's site really isnt that informative as to what one does vs the other and which is better.
so you'd recommend the ICE over the others? I found a huge kit on ebay that had the ultra pro street and a milage miser... Did you keep your OEM spark plug wires?
Originally Posted by Bumpin' Yota
Did you open up the gap on your spark plugs after install?
jacobs ignition for 3.0
well after speaking with Ganoid (learned a lot!!) I am interested in the jacobs ignition situation. seems that if the install is done right that there can be some real gains. the only thing that worries me is that the consensus online seems to be that they often crap out after a few years.
I like the fact that you kept your stock on as well, just in case.
there are several options, one that seems interesting is the off-road kit, which has protection from vibration, seems waterproof and dust proof etc.
also there is an incline adjuster...snake oil?
there are often kits on ebay for reasonable prices, the pro-street was favorably reviewed on 4x4wire for the 3vze application.
by the way if anyone sees a bored throttle body for the 3vze come available please let me know!
anyone with 3.0 jacobs ignitions, would be good to hear from you. would you buy it again?? the thing is...opinions seem to vary widely on the subject. it ranges from "love it!' to..."no effect" to "what a piece of ^^^^"
even my favorite runner site (other than yotatech), the 'mega runner" in sweden (he flew to california to get his downey throttle body bored out! YOU DA MAN!"
didn't like his jacobs ignition...he felt there was no effect.
ganoid on the other hand (who know a LOT! about the 3vze let me tell you)
really likes his. I am gonna try it.
I have one of These and I have no problems vouching for the performance gains when I installed it. I picked mine up for like $100 on EBay a year ago.
Vargntucson
07-04-2015 12:15 PM
