mass air flow sensor
Old Aug 14, 2006 | 10:31 PM
BS Industries's Avatar
anyone know how much one of these will cost me. in the proccess of installing a cold air intake one my 3.0, i got alittle excited and ripped out the plug into the sensor, not knowing i was supposed to romove the wire clip instead of unscrewing the phillips and and yanking her out. soldered it back to gether. ran perfect. but yesterday, i started her up dead within a second. i checked for vacuum leaks, found non. kept trying and on about the 25th try or so she stayed runnin. then i shut it off, started right back up. ran and started perfect all day. but today, no dice. just wouldn't stay running. so i'm assuming the sensor is jacked. local junk yard didn't have any, but i never asked about how much they would cost. I've been told everything from 20 bucks to 500+
Old Aug 14, 2006 | 10:36 PM
dwh91102's Avatar
Your best bet is gonna be either someone on here, or a junkyard. I think there about 190 from autozone.
Old Aug 14, 2006 | 11:32 PM
TNRabbit's Avatar
AND....cold air intake is a waste of time:
www.bobistheoilguy.com
check the link on the left for "filtration test"
Old Aug 15, 2006 | 02:05 AM
TNRabbit's Avatar
Do you have a MAF or VAFM? There is a VAFM on eBay right now.
Old Aug 15, 2006 | 03:17 AM
ovrrdrive's Avatar
My local u-pullit gives AFM's out for $20... But who knows what you're gonna get.
Old Aug 15, 2006 | 04:28 AM
waskillywabbit's Avatar
I'd buy aftermarket. Cheaper, new, and many have a lifetime warranty for a 1/4 of the OEM price w/ no lifetime warranty.
Old Aug 15, 2006 | 05:08 AM
mt_goat's Avatar
The 3.0 has a AFM, not a MAF.
Old Aug 15, 2006 | 05:45 AM
midiwall's Avatar
ref: http://www.bobistheoilguy.com/airfilter/airtest1.htm
Ummm... I don't see any mention in there about cold air intakes. Doing a cold air intake is all about getting _cold(er)_ air into the intake which will increase horsepower. That site talks about the K&N filter, which isn't the same thing.
If you (or the poster) are equating a K&N cone to a "cold air intake" then that's a separate issue. If the original poster is talking about one of those add-on boxes, then that's a 3rd issue (it's still not a good cold air intake).
Old Aug 15, 2006 | 05:55 AM
mt_goat's Avatar
Yeah, now here's a cold air intake:
Old Aug 15, 2006 | 07:26 PM
^VooDoo^'s Avatar
Check the salvageyards, Look into all Toys, There are a few models that use the same one.
Wouldnt you know, I saw one at the cash counter at the last Pic-A-Part I was just at, Thought it funny that I should have picked it up for a spare to, But all I got was my 1st gen rollbar for $25, Sweeeeeet!!!!!
Old Aug 15, 2006 | 07:38 PM
4Crawler's Avatar
Test out the AFM, likely the fuel pump contact is the one that is causing the engine to die:
- http://www.4crawler.com/4x4/CheapTricks/AFM/index.shtml
Old Aug 15, 2006 | 11:02 PM
Spanky's Avatar
have u tried taking the AFM back apart.... the right way.... and tried to re-solder the connections?? Its a PITA, trust me I know! I did the samething not too long ago, but so far my soldering is holding up!
it will save you a hundred bucks or more
Old Aug 16, 2006 | 12:20 AM
thefallman's Avatar
i got one ill sell ya came off my 89 3.slow 4 weeks ago right after i put the ran the truck out of oil up a hill
decided to go 3.4
$30 shipped
Old Aug 16, 2006 | 04:25 AM
Saint_Berzerker's Avatar
I got mine at a junkyard online. Was like 35.00
Try yotayard.com
I wouldn't by a new one, no real point in it.
Old Nov 28, 2006 | 12:19 PM
w211_ryda's Avatar
decided to go 3.4
$30 shipped
if you still have the 3.0 OEM MAF for sale, I'm willing to purchase it for $30 shipped. Please contact me! Thanks!
Old Nov 28, 2006 | 12:26 PM
Elton's Avatar
when will there learn that correct me if im wrong pre 95/obd 2 uses afm
Old Nov 28, 2006 | 01:34 PM
kpaxfaq's Avatar
ahhh i made the same mistake a few months back, i was sick to my stomach when i did it just seeing money go down the drain in front of my eyes but luckily i got it all soldered up!
Old Nov 28, 2006 | 02:47 PM
toyota_mdt_tech's Avatar
Well, first off, its not a MAF, those are only about $160, but you have an air flow meter (AFM), closer to about $500!!! Does the check engine light come on with the key on, but engine off? Reply wiht the answer. You might be able to fix it, "might"
Old Feb 29, 2012 | 06:46 AM
watkin5's Avatar
<engine code after cold air intake install
I have a problem with my 02 taco. i intalled a cold air intake(truckEFX off ebay). Truck was fine for about a week. now I have an engine code. Took it to advance and they said the codes are "pending" meaning teh computer is trying to adjust to the intake??? never heard of this. light is still on. any help? could it be the MAF? truck runs fine just want to know what the light is on for
krimsonone
Sep 13, 2024 09:33 AM
Doug4320
Mar 24, 2018 10:11 PM
RatOmeter
Oct 22, 2015 03:17 PM
tj884Rdlx
Aug 28, 2015 12:04 PM
jetpilot
Aug 15, 2015 06:48 AM
