E-Brake Light Glowing
Old Aug 7, 2006 | 12:30 PM
91_4x4runner's Avatar
My E-Brake light is glowing... After performing a search, I found that it is usually an indicator that more brake fluid is needed. I topped off the fluid and still have the same glowing light. This kinda worries me since im going on a road trip tomorrow. It doesn't feel like the brake isnt disengaging all the way... so I'm not really sure why it's doing it. Any help would be appreciated. Thanks, Eric
Old Aug 7, 2006 | 01:08 PM
wjwerdna's Avatar
hmmm, dig around in your center console until you find something that could be a switch on the ebrake handle.... disconnect it, then stick a paper clip in the harness(connecting the wires)... if disconnecting it or the paper clip make the light go out, then your switch is bad...
i dont know if there actually is a switch in the center console... but that is where i would look first, and am guessing may be the likely culprit
Old Aug 7, 2006 | 03:14 PM
1styota4X4's Avatar
the switch is under the dash by the brake lever if it is the runner in his sig
Old Aug 7, 2006 | 03:43 PM
Thanks, I'll go out and look into it now.
Old Aug 7, 2006 | 04:00 PM
I couldnt get the thing unplugged... but from testing, it doesn't look like the pull lever is depressing the switch all the way. I pushed it in with my finger and the light didn't glow; with the lever, the light glowed. I'll test again when it's darker, but I'm pretty sure the lever is the problem.
AkitaDog
Sep 1, 2015 08:05 AM
yipyip45
Aug 6, 2015 02:05 PM
priest16
15
Aug 6, 2015 07:43 AM
PopsDad1
Jul 30, 2015 02:21 PM
Odin
Jul 15, 2015 09:28 PM
