no oil pressure
Old Aug 16, 2006 | 11:31 PM
linuxrunner's Avatar
no oil pressure
ok so i got a new SR5 guage cluster off craigs list for 20.00, i also got the oil pressure sending unit that goes with it, before i installed the sending unit my oil pressure always sat at 0 but after installing the sending unit when i turn the key to the acc position the oil pressure guage will jump up to what i figure is probably about right, But when i start the truck it drops back down to 0 also guage does not seem to move no matter the RPM's when engine is on. Is there another way to test to make sure that i have oil pressure? i really hope this is just a bad sending unit.
Old Aug 17, 2006 | 05:39 AM
trythis's Avatar
Did you get a new sending unit? or just an old one that came with it?
I am confused about your pressuere reading at 0 before installing the sending unit. Did you use the old idiot light sending unit with the new gauges for a while? Was your oil light on for a while?
xplain, please.
Old Aug 17, 2006 | 08:47 AM
sorry, i got the old used one so it might not work. I unplugged the idiot light before installing the new guages. Once i installed the new/used sending unit is when it started to show the correct (i think) oil pressure in the acc position.
Old Aug 17, 2006 | 08:55 AM
Tdubbs05's Avatar
sure you actually have oil moving around in there? lol man i had a great experience on my 1st car, a 88 celica. i was going 65 on the freeway w/ cruise on. suddenly started hearing clicking that got louder and louder till it started shaking that car. i noticed the oil gauge was at zero and then the car stalled. ended up shooting a connecting rod right out the block...well that sucked by now i got a 4runner!!!
Old Aug 17, 2006 | 10:44 AM
Marc's Avatar
You won't have any oil pressure with the key in the acc position.
You only have oil pressure when the engine is running.
You could hook up a mechanical guage to test your pressure.
Old Aug 17, 2006 | 11:03 AM
i'll try to pick up a guage today. thanks Marc
Old Aug 17, 2006 | 05:08 PM
Marc's Avatar
Keep us posted.
bigjstang
Jun 2, 2025 03:56 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
Odin
Jul 15, 2015 09:28 PM
88yodabasket
Jul 13, 2015 01:32 PM
