Locked up 3VZE - other problems?
Old Aug 18, 2006 | 08:11 PM
hause64oz's Avatar
Well I've decided to keep my 95 4Runner that I royally jacked up... forgot to check the oil on several occasions and ran it into the ground (locked up the engine) at 173000... neighborhood auto shop said they would replace the engine for $3500 incl labor. Im just curious what the chances of them nickel and diming me for other stuff that isnt really messed up ... what else might I have damaged outside the block besides the locked up engine ... ive seriously thought about buying the engine and replacing it myself... i can follow directions and can figure things out, but im not that mechanically inclined.... any advice???
Old Aug 18, 2006 | 08:54 PM
4rockclimber's Avatar
From: From San Francisco, but attending school in Pomona CA
for that price, look into a 3.4..
same motor mounts and it'll bolt to the 3.slow's 5 speed all you need it the motor, the ecu, and the kit from ORS
the kits got everything you need for like $1700
read up and find a buddy whos willing to help, itll be a good learning experience
just a thought
Old Aug 18, 2006 | 09:10 PM
mtsumedi's Avatar
If you ran it out of oil, odds are you just spun a couple of rod bearings. Pull the motor, buy some fresh pistons, rings, and send your crank off. See what the machine shop says and then order the rod and main bearings and slap that ลลลล in there. Not easy but the least expensive route.
I have a 3VZ-E motor with a bent #1 rod. I have a replacement rod and piston to go along with it as well. PM me if you are interested int he motor. It had 118,000 miles on it before I hydrolocked it.
deepmarsh
Aug 6, 2015 03:44 AM
Steven.m.paulk
Jul 13, 2015 01:40 PM
smiley52
Jul 11, 2015 05:16 AM
AaronM
Jul 8, 2015 07:15 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
