Sway bar end broken off
Old Aug 11, 2006 | 02:02 PM
mehret's Avatar
Yesterday when I got home I noticed that the right sway bar end had come off the sway bar which obviously means that the sway bar's also disconnected from the lower control arm. My question is, aside from being annoying to the ears, does this pose as a potential danger when I'm driving. Just by looking at it, I don't see anything that could happen, but I wanted to see what other people think.
Old Aug 11, 2006 | 02:11 PM
waskillywabbit's Avatar
I'd fix it if it were mine and I drove it on the road.
Old Aug 11, 2006 | 02:17 PM
mehret's Avatar
I'm going to within the next couple days. It's just getting the part combined with my lack of ambition that's the problem.
Old Aug 11, 2006 | 04:02 PM
Firefightertaco's Avatar
U could roll over a lot easyer
Old Aug 11, 2006 | 05:22 PM
wjwerdna's Avatar
the only thing i saw is that if both are disconnected, which yours arent, then the sway bar can move up and the ends can rub on the tire.... depending on bushings wear
in your case, i would try to fix it asap, but will be ok driving around town until you get or make the part needed
Old Aug 11, 2006 | 06:40 PM
LOCKnGO's Avatar
You could finnish the job like a lot of us and take the whole dang thing off.
Old Aug 11, 2006 | 07:04 PM
Bumpin' Yota's Avatar
the sway bar just prevents too much bodyroll in sharp high speed turns and is a way to prevent articulation at speed. So long as the sway bar doesnt hit or rub on anything you should be good, until you get it repaired by making quick disconnects! hehe
But if you do go back to the OEM setup, install poly urethane bushings! WOW what a difference!!
Oh yeah and until you repair the sway bar, TAKE IT EASY on the turns...flipping will be waaaaay easier with it disconnected.
Old Aug 11, 2006 | 07:17 PM
LOCKnGO's Avatar
Originally Posted by Bumpin' Yota
the sway bar just prevent too much bodyroll in sharp high speed turns and is a way to prevent articulation at speed. So long as the sway bar doesnt hit or rub on anything you should be good, until you get it repaired by making quick disconnects! hehe
Bumpin' is right you would need to get the feel of how your truck rides w/out the swaybar; if you choose that path. I've had mine out for sometime and I have a 4.5" lift, 3" BS(top heavy?) and roll on 35" BFG's I never really noticed any excessive body roll, but then I do the speed limit most of the time.
the1998sr5
15
Jul 14, 2020 08:35 PM
Sep 4, 2015 09:27 AM
mr_manny
Jul 31, 2015 10:39 AM
coffey50
Jul 28, 2015 10:55 AM
Vargntucson
Jul 4, 2015 12:15 PM
