white smoke AFTER headgasket repair
Old Aug 16, 2006 | 03:48 PM
n8inks's Avatar
I got everything buttoned up on my headgasket repair last night and I just got it running again, but I'm getting a decent amount of white smoke from the tailpipe... is it possible I have a coolant hose running in the wrong place? Hopefully it's not my brand new headgasket, I don't even want to consider that yet.
Old Aug 16, 2006 | 04:25 PM
Elton's Avatar
need a little more info than that
Old Aug 16, 2006 | 04:30 PM
n8inks's Avatar
yeah, sorry. it's a 93 3.0 4runner
Old Aug 16, 2006 | 04:31 PM
n8inks's Avatar
i'm double checking my hoses right now
Old Aug 16, 2006 | 06:13 PM
TNRabbit's Avatar
Did you replace one or both HGs? If one, are you certain the problem was only with the one?
Old Aug 16, 2006 | 06:30 PM
FredTJ's Avatar
Yup, be sure.
White exhaust smoke, especially with a known head/head gasket problem can be coolant pulled into the cylinder(s) and burned.
I've seen that a lot with cracked heads/blown head gaskets.
It's often to dead give away...
Fred
Old Aug 16, 2006 | 06:36 PM
ZUK's Avatar
ZUK
Happened to me too.
Let it run about 30 minutes....it might clear up.
Old Aug 16, 2006 | 07:18 PM
n8inks's Avatar
Yeah, that's it.. and if I would have thought about it a bit it makes sense. When I had it in the garage before I tore it apart, it was running but blowing coolant across the garage... so I unbolted the exhaust and started it and there was no (or little) smoke. I bolted the exhaust back up and it was like a pink floyd concert... my halogen lights on the floor, smoke everywhere.. I was waiting for the guitar solo
It lasted about 20 minutes, so ZUK is right, and after about a month of evenings.. my headgasket is done
Old Aug 16, 2006 | 07:46 PM
Chuki's Avatar
Mine was pretty much like that too, not that bad but for a few minutes it did steam a little... My guess is it was just water that had accumulated in the cat converter and the muffler that finally got steamed out!
justdifferentials
Just Differentials
Jun 13, 2022 07:40 PM
Buckaroo_Banzai
Sep 24, 2015 07:26 AM
_Nicco_
Sep 21, 2015 03:06 PM
LJR
Sep 5, 2015 06:02 AM
