Speedo Corrector Kit installed
Old Aug 14, 2006 | 10:27 AM
-MaTTi-'s Avatar
This is how I made the speedo adjustment. Just made it yesterday. Itīs works fine!
I ordered the Speedo Corrector Kit (KC5380) from Jaycar.
The first surprice was that it was do-it-yourself kit. I didnīt checked it well enough from Jaycar. But no problem, Iīve tined before. It took 1― hours to get it done.
I didnīt found better case (wooden tobacco case)
There is three wires from sensor. The right one was the green-red one. First I measured the voltages AC and DC and seems like I have to tin one optional resistor more. But when I tried it first time, nothing happened. I have to take it (resistor) off. Then everything works fine. I can adjust speedometer 0-99 % more or less! I love this.
Things to do:
-you have to cut this green-red wire and tin wires from there to this corrector
-you need +12V to corrector(when key is ACC-position). I took it behind the radio. And one ground too.
-good and simple place for this corrector is behind co-drivers side panel next to pre-heating timer (I have diesel).
Dieselmann
Feb 19, 2019 02:57 AM
jerusry
Oct 19, 2015 05:28 PM
Sep 4, 2015 09:27 AM
Coreyr384
Jul 10, 2015 11:13 AM
crashburnoveride
Jul 10, 2015 06:39 AM
