How often do water pumps go?
Old Aug 16, 2006 | 08:59 AM
PWDR PG's Avatar
Post How often do water pumps go?
I am rebuilding my engine and am wondering if it would be a good idea to replace my water pump while its so easy to get to. My truck had 170,000 on it when i pulled the engine. Has many people had their water pumps go? Let me know.
Old Aug 16, 2006 | 09:23 AM
eric-the-red's Avatar
I would say definitely replace it, I don't know how often they fail but with 170,000 your probably pushing your luck by reusing the old one. If you've got a V6 and you have to pull everything off to replace it later you won't be happy.
Old Aug 16, 2006 | 09:44 AM
TNRabbit's Avatar
which engine?
Mine went @ 198,000 onmy 3.0. While you're in there, replace the oil pump & seals, and adjust the vavles.
Old Aug 16, 2006 | 09:47 AM
rngrchad's Avatar
mine went at 140,000 miles
Old Aug 16, 2006 | 10:53 AM
surf4runner's Avatar
replace it! why wait for it to go another 10k and have to replace it then.
likely for a new to go 170,000 if its replaced NOW
Old Aug 16, 2006 | 11:56 AM
Tim_Snapple76's Avatar
Save yourself the time and go ahead and replace it. You might also look at replacing your fan clutch. Pretty sure that the fan clutch and the water pump have the same life expectancy. Tim
upongame619
Aug 1, 2015 12:12 AM
TJWilly
Jul 31, 2015 02:05 PM
jjrbus
Jul 19, 2015 02:06 PM
Snort
Jul 19, 2015 07:03 AM
Jonny246
Jul 12, 2015 04:51 AM
