speedometer adjustment question
Old Aug 13, 2006 | 04:10 PM
FredTJ's Avatar
On the gen II 4Runners, how is the speedometer adjusted for larger tires.
Coming from a Jeep Wrangler (TJ) background, where it's easy.
The Jeeps have a speed sensor (gear driven) in the outout tailhousing of the xfer case. Simply remove one bolt, pop the sender out, pull the gear off the end, replace with a different toothed geer (which DC sells a wide selection of, suprisingly enough), pop the speed sensor back in, replace bolt and bingo.
Trying to wade through all the information and it looks like maybe the 4Runners have a cable, but it looks as though they may have a speed sensor.
I'm looking at '92's, '94's and 95's.
Thanks,
Fred
Old Aug 13, 2006 | 04:40 PM
4runnermt's Avatar
Hey Fred, I am wanting to know this exact same thing, hopefully someone will chime in! Welcome to yotatech!
Old Aug 13, 2006 | 04:42 PM
mt_goat's Avatar
Yep Toyotas have a speed sensor in the t-case too. The gears along with the shaft can be replaced with different sizes. There are mechanical driven (cable) and electronic senders depending on the model.
Old Aug 13, 2006 | 04:44 PM
4runnermt's Avatar
Hey MT Goat, do you know of a good place to get the gears?
Old Aug 13, 2006 | 04:55 PM
mt_goat's Avatar
You might have to get a complete sender with gears from the dealer, Marlin Crawler or the junk yard. New they cost about $200 for the electronic senders. I don't know where you'd find just the gear and shaft (the shaft and gear are joined or fused together as one) but you can swap them between senders with a little modification). I may have a spare 18 tooth mechanical sender soon.
Old Aug 13, 2006 | 05:08 PM
mt_goat's Avatar
Here's a pic of the location of the sender in my old transfer case: http://community.webshots.com/photo/...42310107nlgRvA
Here's a pic of the two different senders I've seen, the mechanical is the upper one. http://community.webshots.com/photo/...42310107nNUnQh
Here's a pic of the gear markings, one is a 20 tooth, one an 18 tooth: http://community.webshots.com/photo/...42310107axatpc
The 20 tooth was in my 93 V6 4x4 auto tranny SR5 with 4.88 gears and 31 inch tires from the factory.
The 18 tooth mechanical sender was in my gear driven transfer case from Marlin Crawler.
Old Aug 13, 2006 | 05:17 PM
FredTJ's Avatar
Pretty similiar to the Jeep ones, though all of those are electrical.
Anyone very find a "gear tooth" chart that shows the "correct" number of teeth for the speedo sender based on tire size and diff gearing ?
There are a lot around (charts) for the Jeeps.
Thanks again,
Fred
Old Aug 13, 2006 | 05:21 PM
Elton's Avatar
anyone ever try This
Old Aug 13, 2006 | 05:45 PM
mt_goat's Avatar
Thanks again,
Fred
Its possible that Jeep uses the same gears, I heard they use essentially the same auto transmissions.
Old Aug 13, 2006 | 06:03 PM
FredTJ's Avatar
Ah, some, kinda, sort of.
The TJ's ('97 to current, auto trannies) use either a TF999 (904) or a RLE42RE (basically a bastardized 604/606).
The Cherokees used the "AW4" which is the A340F with a 231 xfer case.
The auto 4Runners use the A340H (intergrated xfer case).
Fred
Old Aug 14, 2006 | 09:13 AM
4runnermt's Avatar
I asked this lady in the parts at the dealer and she didn't know anything at all about these parts, so maybe I'll have to call again and try to talk to someone who knows! I hate having my speedo off.
Old Aug 14, 2006 | 10:24 AM
-MaTTi-'s Avatar
This is how I made the speedo adjustment. Just made it yesterday. It´s works fine!
I ordered the Speedo Corrector Kit (KC5380) from Jaycar.
The first surprice was that it was do-it-yourself kit. I didn´t checked it well enough from Jaycar. But no problem, I´ve tined before. It took 1½ hours to get it done.
I didn´t found better case (wooden tobacco case)
There is three wires from sensor. The right one was the green-red one. First I measured the voltages AC and DC and seems like I have to tin one optional resistor more. But when I tried it first time, nothing happened. I have to take it (resistor) off. Then everything works fine. I can adjust speedometer 0-99 % more or less! I love this.
Things to do:
-you have to cut this green-red wire and tin wires from there to this corrector
-you need +12V to corrector(when key is ACC-position). I took it behind the radio. And one ground too.
-good and simple place for this corrector is behind co-drivers side panel next to pre-heating timer (I have diesel).
Old Aug 14, 2006 | 10:39 AM
mt_goat's Avatar
Wow that's interesting, do you just calabrate it somehow? Did you have to actually solder everything onto the circuit board?
Old Aug 14, 2006 | 11:20 AM
-MaTTi-'s Avatar
Can you see those small swithes which have numbers 0-9? If you want a correction of 5 %, simply set right one to "5". Left one alters the correction by tens, so setting of "1" on left and "5" on right results in a 15 % correction.
I know how much I need correction before, so I just set "6" to right switch. Now the speedo´s reading is just right.
Old Aug 14, 2006 | 12:16 PM
Saint_Berzerker's Avatar
Here's a calcuator for calculating speedo with bigger/smaller tires:
http://www.1010tires.com/TireSizeCalculator.asp
Old Aug 14, 2006 | 12:48 PM
Glenn's Avatar
I used an adapter from Tacoma Speedometer & Instrument. It's a little gear thingie that goes on the tailshaft. Mine is a mechanical speedometer, so this might not work for an electronic one.
Old Aug 14, 2006 | 03:48 PM
4runnermt's Avatar
I must have an electronic speedo since my transfer case looks just like Mattis.
Blamalam
Mar 12, 2022 07:34 AM
altydog
Jul 28, 2015 10:20 AM
kirkrunner
Jul 27, 2015 07:59 PM
TammyMarie
Jul 15, 2015 11:14 AM
wilbertd
Jul 6, 2015 07:39 AM
