Water Comming Out From Under Dash
Old Aug 14, 2006 | 04:21 PM
keithguts's Avatar
Ok, when I have my AC on, and I make a left or right turn, I have water comming out from under my dash inside the truck. Can anyone tell me what this is, where to look to fix it, or what is causing it to do so. Please help as it is not fun driving around with wet feet
Attached Thumbnails Water Comming Out From Under Dash-017.jpg   Water Comming Out From Under Dash-015.jpg
Old Aug 14, 2006 | 04:39 PM
JEBSR5's Avatar
Sounds Like
Your AC condensation hose is full of debris. You can crawl under when exhaust is cold and use something like a pipe cleaner and clear it out. You may get a face or arm full of water and it may take a few times.
Old Aug 14, 2006 | 04:41 PM
ovrrdrive's Avatar
I always just took a blower from the air compressor and just gave it a quick shot of compresed air and it usually blows it all out and dumps about a gallon of water.
That's what it sounds like to me too...
Old Aug 14, 2006 | 04:58 PM
keithguts's Avatar
Where about is it located. Also thanks for the info.
KG
Old Aug 14, 2006 | 05:05 PM
Firefightertaco's Avatar
I think it is the little black hose that comes out of your firewall and it points down at a 45 degree angle, and its right above your exaust where the two headers come together and go down into one pipe on the passanger side.
Old Aug 14, 2006 | 06:07 PM
95RunnerSR5's Avatar
on my 95 runner, its the black hose that hangs down right above the passenger side frame rail, right behind the wheel
Old Aug 14, 2006 | 06:22 PM
whitetaco02's Avatar
i got my cleaned out on my 4runner and it will drip like a SOB. I Love It!! Means it is doing its job. I definitely recommend doing it.
Old Aug 14, 2006 | 09:12 PM
Tim_Snapple76's Avatar
Happened to me also. Run a coat hanger up in the drain hole. Works every time.
warrenjcarlson
Jul 22, 2016 11:47 AM
vasinvictor
Jan 20, 2016 12:39 PM
yamaha73
Jun 18, 2015 06:19 PM
infinityisfive
Jun 16, 2015 06:51 PM
