head gasket.. i'm stumped
Old Aug 10, 2006 | 09:47 PM
n8inks's Avatar
I'm getting everything back together on my headgasket project for my 94 4runner v6. I'm putting the new timing belt back on and I can not seem to properly locate the #1 idler pully (the one that hangs on the front of the right head)
There are two bolt holes, one in close to the center of the engine, and one out towards the exhaust. I believe the one on the outside is for the power steering pump bracket, but the one in the center leaves the idler too low.
Does anyone have any photos or anything to help me? it should be pretty easy, but it just won't go together.
Old Aug 10, 2006 | 09:58 PM
dwh91102's Avatar
Old Aug 10, 2006 | 10:02 PM
n8inks's Avatar
yeah, there it is.. your uses a spring it looks like, and mine is hte hydraulic thing, but it should mount the same shouldn't it?
Old Aug 10, 2006 | 10:21 PM
n8inks's Avatar
ok, i just found this photo (these are not my heads) and I'm wondering... is it possible i switched the heads on my engine left to right and the one on the right now doesn't have the hole i need? and if so, how completely screwed am I?
Old Aug 10, 2006 | 10:35 PM
DeathCougar's Avatar
Yes it is possible to switch them left to right...things wont bolt up properly (as is your issue) but you can accidently get them backwards. You are not completley screwed, just take it all back apart, switch the cams, etc etc and putit all back together...the correct way this time lol
bigjstang
Jun 2, 2025 03:56 PM
Jason Webber
Sep 2, 2015 03:30 AM
Stull
Aug 28, 2015 05:53 AM
stock87yota
Jul 31, 2015 10:08 AM
