PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 [68] 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. Manual Hub Parts - Best place to get?
  2. 91 v6 wont start, very strange problem
  3. exhaust smell
  4. (new) 1992 pickup 3.0, head gasket repaired, other issues?
  5. '88 Sunroof replacement
  6. Rupture in fuel line
  7. ignition
  8. 91 3.slow auto won't downshift/stalls when new TPS installed.
  9. Drive shaft
  10. egr block off
  11. Four Wheel Drive No Good in Snow?
  12. 88 Pickup Heater Controls
  13. 89 22re pickup heater core
  14. Whining radiator and above average temperature.
  15. build new dash ideas
  16. 1992 4 runner electrical issue 3.0 v6
  17. Blazeland vs OME kit?
  18. Alternator Load Capability
  19. trany and transfer swap from 22re to v6
  20. Advice on 91 pickup engine swap
  21. Amsoil Engine Oil Test
  22. water like from rain
  23. '87 4Runner Hi-beam headlight problem
  24. mechanical to electrical speedometer
  25. 22re Running Rough When Cold and at High RPM's
  26. replacing front end gaskets
  27. new here,
  28. 22re Rod Bearing Install Cant Turn Crank
  29. 3.0 running too cool.... ?
  30. Intake Valve Suggestion
  31. '92 truck w/water in oil pan
  32. 7mge in 87 4run with A340F
  33. Truck missing during low acceleration
  34. 95 4Runner Intermittent stalling CHALLENGE
  35. Hello from Maryland
  36. trail gear rear bumper
  37. Went to adjust the valves on my 22re and found a surprise...
  38. 86 22r head gasket blown
  39. Latest Projects: Heat Shield and Engine Light
  40. Lower hose on power steering reservoir -- special?
  41. Vacuum Line Question for a 94 3vze
  42. 87 Front Caliper anti-rattle spring
  43. HELP!! weird issue and.no CEL!!!!
  44. 89 suspension question
  45. Dash clock 24 hour format
  46. Pulling Distributor on 3VZE......
  47. 92 22RE injectors not firing, fried 2 ecms
  48. Power to Manual Steering Conversion Question
  49. VAFM Wiring pictures/diagram?
  50. '91 Toyota unlocked hubs are turning
  51. Cab roof/door weatherstripping.....
  52. 1990 4 runner problem
  53. automatic transmission fluid question
  54. mystery vacum line
  55. Blown Head gasket
  56. "hidden" Timing chain cover bolt either stripped or cross threaded.
  57. Having a time figuring this skip out...
  58. 22re coolant loss,headgasket?
  59. torsion bar kift
  60. [First Post!] Looking at an '89 4Runner on CL. Seller asking 5000 OBO. Fair price?
  61. First 22RE rebuild
  62. Code 21 with working O2 heater?
  63. intake popping help
  64. Oil Pump Replacement Necessary?
  65. help3 Problems with installing sr5 cluster
  66. battery/wiring/starting issue please help
  67. Cold start temperature switch - interchangable?
  68. Did i mess my starter up
  69. Vaccum and Ignition timing questions ?
  70. swapping a v6 automatic tranny for a 5 speed
  71. 89 pickup 3.0 high idle issue
  72. OME to fix rear sag
  73. removing bj spacers
  74. Ideas on this front end sound? Bad hub? Axle shaft joint?
  75. Type of power steering fluid?
  76. Multiple Questions, Please Help?
  77. 95 4Runner- 3VZE Cylinder Head Removal
  78. Any way to extend seat tracks on 2nd gen 4R?
  79. 89 1st gen 4Runner- electrical problem
  80. OEM shock selection
  81. Need help identifying brackets and also need help with dash panel lights
  82. Help: Noise on deceleration 3vze Engine Automatic Transmission? Gearbox? Front Diff?
  83. Manual trans. not shift smoothly
  84. Help me buy my first yota pickup
  85. 22RE wont rev past 1000rpms after rebuild
  86. EFI Harness Score!
  87. Headers
  88. OEM carpeted mats for '87 4Runner?
  89. Locked Brakes?
  90. 93 Pick Up Factory Service Manual online version
  91. VAFM connector help
  92. engine swap
  93. Sas Ideas
  94. Should alignment be this far off?
  95. operating temp slowly rising
  96. 87 turbo 4runner no dash lights and low power after a new radio.
  97. Need Help ASAP!! Headgasket Job / low compression on Cyl. 3
  98. LSPV Mounting Bracket
  99. 1987 runner rear window glass
  100. New Winch Bumper in the works
  101. Drivetrain lift & BJ Spacer question
  102. 1990 6cyl Exhaust Manifold Take Down
  103. 89 yota 22re just stopped running
  104. 94 4runner 3.0 timing isue
  105. Power locks/ windows
  106. 22RE Not starting easy cold or warm
  107. Best Fitting Floor mats? 89 Ext. Cab
  108. Low rough idle after long drive
  109. Driveline Vibration Problem
  110. Speaker Location... Please watch video :)
  111. Light Mounting, Keep stock look on a 93 truck
  112. 1994 22RE Pickup Starts Then Dies
  113. 4 Wire Oxygen Sensor Wiring for 1st Gen 4Runner
  114. 1990 2wd rear sag -FJ80 coil?
  115. Marlin Crawler Shift Lever Socket Issue
  116. Any reviews on Centerforce 23500100 DFX Series ?
  117. New Engine won't start 1993 3.0
  118. 95 22re pickup horrible mileage
  119. Question about brake caliper pistons
  120. HG or rpm signal....
  121. 22re to 22r swap no fuel
  122. Need help diagnosing an intermittent gremlin
  123. 4runner wiring help needed
  124. Tailgate Wiring Nightmare
  125. Oil smells like gas
  126. True value of a 1994 toyota truck with new motor? 2800 Good deal?
  127. Trying to locate a vacuum siwtch for a 1993 22re
  128. Pic of Fusible link of cig lighter '89 pickup
  129. Wire disconnected on driver side under kick panel??
  130. I have a 22r ECU in my 1988 EFI pickup???
  131. tranmission miss shifting
  132. Fuel Filter
  133. 94 pickup 3vze 3.0 inconsistent idle and no high warm-up idle??
  134. Another 3vze mystery leak
  135. Getting a bit more life out of a 3.0 that's overheating?
  136. R150 Trans Pulling Hard Left in 4WD
  137. Part compatability
  138. 22re piston ring advice
  139. R150 to R151 Transfer Case compatibility
  140. 2nd Gen 4 runner 'hi-clearance' fiberglass rear panels
  141. Trouble setting idle. AAV problems?
  142. 87 4runner code 11
  143. NGK, Denso, & Other Spark Plug Wires
  144. 22re Blew a coolant hose, now won't rev passed 2000rpm
  145. Cylinder head-re installation, chasing head bolt holes
  146. Front half axle replace?
  147. Spark plugs and wires
  148. timing chain play. pics
  149. Auto shift patterns
  150. Auto shift patterns
  151. Cruise Control
  152. Dashboard warning lights question?
  153. Swap to solid axle or just keep ifs?
  154. Value of 1987 pickup 4x4
  155. Whine noise from under truck. Throw out bearing? Clutch? Worse?
  156. Zuk mod
  157. Motor rev
  158. Can anyone reccomend a shop?
  159. 1990 pickup parts
  160. Poor Ride Quality.... New Bilsteins 5100s and my ride quality still sucks
  161. engine will not stay running after starting , cel code 14
  162. What is this part? 93 22re
  163. 89 v6 no power and idled roughly
  164. Suspension And Body Lift Quotes. Is This A Rip-off Or Typical Prices?
  165. ARRGGHH!! 'Runner dies on road , starts as tow truck pulls up ...
  166. new engine break-n oil
  167. Front end noise
  168. 2005 Tundra V8 Heater Problem
  169. 22re weird sound from exhaust at idle. Video
  170. 94 vsv for fwd
  171. Windshield replace
  172. 88 3.0 4runner wont start
  173. Heater control valve cause overheat?
  174. 3vze rebuild or reman?
  175. 94 power loss and terrible fuel mileage
  176. When cold my 3.0 has bad hesitation and throws the knock sensor code
  177. 3.0 Running rough / No Power after head gasket job
  178. screw laying inside the plastic cap on the rear of the RH delivery pipe ? ? ?
  179. distributor/timing chain questions
  180. Help! Brake options for 2wd Yota- New Arm is interfering with caliper.
  181. door issues
  182. door issues
  183. How do I remove the wiper arm??
  184. W55-W56 Trans mount
  185. Ring and Pinions
  186. Help with rear 3rd member
  187. truck cranking but not starting
  188. 93 runner 3.0 reversed jumper cables and now no power.
  189. Leftover bracket after engine install
  190. 4wd Problems
  191. 1986 4Runner 22RE bad ignition/ key switch interrupt power to fuel pump?
  192. Dead Cylinder,1100 Miles on Rebuilt 3VZE
  193. How to reach small coolant hoses
  194. Pistons dont want to play.....
  195. Headlight issues
  196. 86 2wd seats
  197. Blew the headgaskets on my 3.0, now what?
  198. ECM/ECU Question!
  199. Can't separate t-case from transmission
  200. IFS rear axle build with v6 ARB so frustrated!
  201. Clutch problems
  202. 88 4runner fuel dripping from exhaust pipes
  203. Timing Chain Issue.....Help!
  204. Possible Cracked head, 22RE,
  205. 03 headlights in a 92 4runner
  206. help me figure out this noise? (mp3)
  207. genuine toyota 2+OL leaf springs
  208. Just replaced shifter seat and...
  209. rear end traction
  210. fuel sending unit
  211. Elusive engine tick. Winner gets a cookie
  212. 4Runner/ Truck doors the same, 1994?
  213. Gas door woes
  214. New Head Gasket?
  215. Lift questions
  216. Odd cold start problem.
  217. Sunroof
  218. black transmission fluid????
  219. anybody know what truck this bracket is off?
  220. oil pan windage tray
  221. Sputtering...
  222. 92 4Runner Blazeland LT steering issue. Front end is wandering.
  223. Connectors on the valve cover???
  224. The leak of DOOM! 3VZ-E?!?
  225. Best Head Gasket for 22RE?
  226. Help Tps wont sit right
  227. 1987 DLX 22RE, auto --radiator choice
  228. Clutch bleeding stops slipping...for a week
  229. 1991 pickup cold cranking issues
  230. Need source for transmission detent cable for 89' V6 4Runner.
  231. Voltage light
  232. 95 3vze intermittent power loss when I press the clutch
  233. What Timing are you running 3.0
  234. Clutch master cylinder warning!
  235. 94 3vze pickup cooling too much after new head gaskets???
  236. 1987 4runner DLX 22RE automatic
  237. W56b transmission on it's way out
  238. Stupid battery question
  239. Transmission Compatibility ?!? Please help!?
  240. 2nd Gen 4runner wont start
  241. 1989 pickup 3.0 4x4 manual trans
  242. Stock 1987 XtraCab pictures
  243. no top end, strains to do interstate speed limit
  244. 1988 Toyota 4ruuner - good deal?
  245. Shock size help!!
  246. 2WD rear lift shackles
  247. 22r fan clutch
  248. 88 toyota 4x4 truck with a 92 22re efi wiring help
  249. rolled 86 runner
  250. New member here. 1990 2wd
