Ring and Pinions
Old Dec 15, 2013 | 01:00 PM
Gasportsj7's Avatar
Ring and Pinions
When buying ring and pinion gears do they typically come with the front and rear set? Or do you have to buy two??
Old Dec 15, 2013 | 01:04 PM
BigBluePile's Avatar
Um....no...? Ring and pinions come together in a set. So, to redo the front and back you'll need two sets among other stuff.
However, front gears are a different size than rear if the vehicle is IFS.....
Old Dec 15, 2013 | 02:14 PM
Gasportsj7's Avatar
What all do I need? Front and rear ring and pinions and replacement bearings? or should I buy an entire install kit with bearings and races and seals?
Old Dec 15, 2013 | 02:32 PM
JasonYota's Avatar
What you need depends what your doing
Old Dec 15, 2013 | 02:36 PM
sebastianholmes's Avatar
if you dont know what you need i would not suggest you even changing the gears. have someone else do it. its real easy to mess up.
Old Dec 15, 2013 | 05:51 PM
gearinstalls.com
Old Dec 15, 2013 | 07:09 PM
Gasportsj7's Avatar
well i have a buddy that is helping me with it that has done it before I just have to buy the parts. How much would an mechanic charge me just for labor? Just curious
Old Dec 15, 2013 | 07:17 PM
JasonYota's Avatar
Like everything, it depends on your area. Call around different places for quotes. Contact ZUK on here, his work is top notch.
kawazx636
Oct 6, 2021 03:03 PM
dzldust
7
Oct 6, 2015 05:39 AM
hiluxinargentina
Sep 30, 2015 05:51 PM
charlie_fong
Sep 27, 2015 10:06 PM
Odin
Sep 26, 2015 06:56 PM
