engine swap
Old Dec 26, 2013 | 08:37 PM
mikejr's Avatar
engine swap
i just placed a 1992 3.O engine out of a toyota 4 runner that was hooked up to a manual tanny into a 1995 toyota 4 runner with a automatic had it started barely it just wont run any ideas
Old Dec 26, 2013 | 08:49 PM
jimmyjoebillybob's Avatar
Are the sensors the same andd did you use the engine wire harnes off your 95 or the 92?
Old Dec 26, 2013 | 08:55 PM
mikejr's Avatar
i used the harness that was on the 95 and not sure about sensors all the plugs were the same also was wondering if you have to purge the fuel rails for air or if it does it on its own
Old Dec 26, 2013 | 09:01 PM
I think it should on its own but i could be wrong. I would go through all the plug ins and make sure they are good and tight and also check them at the ecm. good luck
Old Dec 26, 2013 | 10:13 PM
dropzone's Avatar
Fossilized
probably need the ECU too
Old Dec 27, 2013 | 09:33 AM
Gamefreakgc's Avatar
There's some sensors on the water bypass that a late model AT needs that a MT doesn't. You might have to swap back in the old water bypass from the original AT motor.
icentropy
Sep 16, 2020 02:47 PM
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
mskalmus
May 28, 2017 07:51 AM
steve miller
Oct 10, 2015 01:40 AM
coryc85
Sep 9, 2015 06:24 AM
