Help with rear 3rd member
Old Dec 15, 2013 | 11:59 AM
Barry&Amanda's Avatar
Hello Barry here from wv . I resently bought a 91 ex cab 4x4 for a work truck . 4 cyl 5 sp runs like a clock love it .
Now to the problem I was driving to work I hear a high pitch whine from the rear end , I only drive 15 miles to work , when I get there I fell there rear it's cool so I fig it will show its self. On the way home on a gravel road I could push clutch in and let coast at around 5 mph it would start to catch , clunk clunk clunk and stop the truck .
When I got home pulling up my driveway which is only 3% the truck stops pulling after making a fast buzzing noise . Now the driveshaft turns but not the rear wheels not even on jack stands? No noise at all now. What has happened ?
I pulled he rear driveshaft you can turn the yoke by hand easily and seems to be no slack in the pinion shaft .
Removed pinion nut still no slack and the pinion and yoke splines are good so I know
1: yoke is good
2 pinion to yoke splines are good
3: I don't think the pinion shaft is broke
What law is there
Old Dec 15, 2013 | 12:05 PM
millball's Avatar
broken axle?
Old Dec 15, 2013 | 02:46 PM
Wouldn't the wheel fall off?
I put it up on jack stands and checked the wheels for looseness there was none and when I turned one the other turned a little but not much
Old Dec 15, 2013 | 02:51 PM
sebastianholmes's Avatar
nope wheel wont fall off on those. the bearing is pressed onto the axle. no c clips or anything to hold the axle in the diff.
Old Dec 15, 2013 | 02:52 PM
millball's Avatar
Sooner or later, probably sooner, but not necessarily immediately.
Old Dec 15, 2013 | 02:59 PM
Oh that's news good news I will pull the axles thank you
Old Dec 15, 2013 | 03:00 PM
millball's Avatar
Ultimately, unless by some remote twist, there is some tranny issue; You are going to have to open up the rear axle unit in order to fix it.
That process will show whether or not there is any axle trouble before you ever have to get into the 3rd member.
Old Dec 15, 2013 | 03:10 PM
Old Dec 17, 2013 | 12:56 AM
Ok update , for you all, the pinion gear is shot it has no teeth left on it thank you all for the help now rebuild or replace ??? I see 3rds on e bay all the time around 300 - 350
Old Dec 17, 2013 | 05:27 AM
thefishguy77's Avatar
Check craigslist and the YT classifieds you see a lot of bolt in 3rds for sale from people that have done SAS's or just bought new clusters to bolt in. Worth a look. Be careful if you do eBay or amazon because there is good and crap out there. I routinely see 4:10's cheap $50 a cluster 4:56&4:88 for 100-150 a cluster more if it has a locker.
Old Dec 17, 2013 | 02:47 PM
I am the 3 ed inner if this truck I think I have a v 6 rear how can I tell it looks line it has 3 ribs and it has 4 spider gears and it's a open dif
Old Dec 17, 2013 | 03:02 PM
dropzone's Avatar
Fossilized
http://home.4x4wire.com/erik/diffs/
Old Dec 17, 2013 | 03:29 PM
That helps a lot thank you
Jun 1, 2021 01:51 PM
jerusry
Oct 19, 2015 05:28 PM
BeMiceElf
Oct 10, 2015 09:40 PM
