How do I remove the wiper arm??
Old Dec 15, 2013 | 01:07 PM
mldave's Avatar
On my 86 Toyota truck I took off the plastic cap and removed the locking nut with a 12 MM wrench,but how does the wiper arm come off the stud?This is on the drivers side.
Old Dec 15, 2013 | 01:12 PM
dropzone's Avatar
Fossilized
It should just slide off. Probably stuck...put something thin(plastic, cardboard) on the cowel to protect it and lightly pry it off with a pry bar/claw hammer
Old Dec 15, 2013 | 02:12 PM
mldave's Avatar
Thanks man,I'll try that tomorrow.If that don't work Ill borrow a little puller if I can.
Old Dec 15, 2013 | 03:31 PM
wyoming9's Avatar
Red face
A little of your favorite penetrating spray does wonders as well
Old Dec 15, 2013 | 04:18 PM
julsruls's Avatar
no puller needed. elbow grease and something to pry. Probably can just wiggle it enough ad it would come free.
Old Dec 15, 2013 | 05:27 PM
Cyberman's Avatar
Pull it away from the the wiper to remove the spring tension, then wiggle it off.
Old Dec 16, 2013 | 08:18 AM
bbrideau's Avatar
grab the arm pull up and wiggle side to side. 20+ years of it being on there will make it not want to move. i was so pleased when i finally got my new ones. my windshield is clear now!
Old Dec 16, 2013 | 01:44 PM
mldave's Avatar
Thanks men for the replies.Put some WD-40 on the threads this morning and this afternoon I worked the drivers side off with a little struggle and tugging and back and forth motion.The passenger side was still jammed on however and a friend helped me as I used the claw hammer gently and he tugged.All changed and working well.
Old Dec 16, 2013 | 06:23 PM
dropzone's Avatar
Fossilized
Good to hear...they can be a PITA sometimes..
okamikai
Apr 30, 2018 10:19 PM
ghostmoney
Jan 28, 2018 11:42 AM
rusty904
Mar 27, 2017 05:20 PM
Jcrawl94
10
Oct 24, 2015 04:34 PM
msane99
Jul 17, 2015 10:13 AM
