help3 Problems with installing sr5 cluster
Old Dec 29, 2013 | 08:19 PM
412eRunner's Avatar
ok so installed an 88 sr5 auto 4cly cluster into my 88 dlx 4cly i installed the sr5 oil sending unit before ever hooking up the cluster. Cluster and everything works but the 3 problems.
1st. I dont get a Check Engine Light in the ON position or at ALL.?? (Bulb is Good) and it didnt work when dlx cluster was in.
2nd.The Temp Gauge goes straight up to Hot in ON position and will stay there till i turn truck off?? (no matter what temp the truck is at.
3rd. The Oil gauge wont read? it stays on bottom.
any help will be appreciated Thankz...
Old Dec 29, 2013 | 08:27 PM
86toyotaprerunner14's Avatar
I would make sure the oil pressure sending unit isn't bad. Make sure you hooked up all the wires correctly.
icentropy
Sep 16, 2020 02:47 PM
coryc85
Sep 9, 2015 06:24 AM
Cplmike
Jul 8, 2015 08:47 PM
raiderhawks00
Jul 8, 2015 06:23 PM
bryan34w
Jul 6, 2015 05:53 PM
