Manual trans. not shift smoothly
1988 pickup 4x4 extra cab 5gear ok when shift any gear i feel the teeth of gear in any change run good but i think its not normal. The fluid of clutch pump was checked
What can be causes of this
check the clutch free play adjustment, and also make sure that the bracket that holds the clutch pedal isn't cracked... it'll flex if cracked, and not allow the clutch pedal to have full play.
crammit442
7
11-29-2017 12:30 PM
Shaun Crystal Gomban
07-30-2015 10:13 PM
