Getting a bit more life out of a 3.0 that's overheating?
Old Dec 20, 2013 | 09:06 AM
carlspeed's Avatar
Diagnosing overheating **solved**
Got truck and it got warm on me. Didn't over heat, but it was close. Added water to it and bled the system. Probably should do compression test.
Old Dec 20, 2013 | 09:40 AM
HighLux's Avatar
Dont put any fix it crap in. Just make it harder to clean up when you do do it.
If you dont need to run it....dont till you do the gaskets.
You will just cause unnecessary damage.
Old Dec 20, 2013 | 10:37 AM
carlspeed's Avatar
That's kind of the thing. I'm not so sure I even want this motor. It looks like swapping is a way better option, so if this block gets destroyed, so be it.
Old Dec 20, 2013 | 10:43 AM
The Tick's Avatar
I guess if you're going to do an engine swap anyway, just put some of that fix-a-leak crap in it and run it until it goes.
Old Dec 20, 2013 | 10:57 AM
jtinco's Avatar
If you do mess up the motor you can do an engine swap like you mentioned. If you decide to keep the 3.0 there are plenty on the market from others doing swaps and parting trucks so you should be able to find one cheap. Either you might as well run what you have.
Old Dec 20, 2013 | 01:37 PM
carlspeed's Avatar
Hey tick, you don't know a guy who used to autocross up there named Loren, do you?
Old Dec 22, 2013 | 01:49 PM
The Tick's Avatar
It doesn't ring a bell. What kind of car did they have?
Old Dec 22, 2013 | 02:25 PM
carlspeed's Avatar
Back then I haven't the foggiest. I don't doubt it was show though!
Old Dec 24, 2013 | 02:32 PM
The Tick's Avatar
Ok, just wondering.
Old Dec 24, 2013 | 02:38 PM
carlspeed's Avatar
So I did some work to the truck today. I swapped the hubs, swapped an axle, and bled the coolant.
No issues at all. Love this truck!
Old Dec 24, 2013 | 03:41 PM
Duffdog's Avatar
Dumb question, but did you replace the radiator? That would probably completely solve your overheating issue unless you have a blown HG. If you install this specific radiator you should be good.
http://www.ebay.com/itm/BRAND-NEW-1-QUALITY-RADIATOR-FITS-88-95-TOYOTA-PICKUP-4RUNNER-4WD-3-0-V6-3VZE-/170727081726?pt=Motors_Car_Truck_Parts_Accessories&hash=item27c02086fe&vxp=mtr
My truck had the same issue until I changed it out. I kept thinking it was the HG or the water pump or bleeding the coolant, but it wasn't any of that. And, it would always overheat after about 15 minutes every single time.
Old Dec 24, 2013 | 05:20 PM
carlspeed's Avatar
Nah its running fine now.
Old Dec 25, 2013 | 09:47 AM
Duffdog's Avatar
I don't know of a way to test it. I took my existing radiator out and filled it with muriatic acid to clean it. When I put it back in cleaned it STILL overheated. Only changing the radiator solved my overheating problem.
Old Dec 25, 2013 | 10:26 AM
carlspeed's Avatar
It's just a play truck. If it ever does it again I'll swap the radiator.
Old Dec 25, 2013 | 10:57 AM
HighLux's Avatar
Why dont you actually do as suggested and run a compression test on it?
Time to stop guessing and do some real diagnostic work.
Dont have a tester? Try and borrow or rent one. Or go buy one. Every man should own one.
Another little test is to start it up....take of radiator cap....rev it up a few times. any bubbles or coolant shooting out radiator?
Old Dec 25, 2013 | 11:40 AM
wyoming9's Avatar
Red face
Are you always needing to add coolant??
Have you pressure tested the system ??
If it is the original radiator it bet it is just clogged.
to slow down the over heating you need to find the cause??
Old Dec 25, 2013 | 11:49 AM
carlspeed's Avatar
I saw some bubbles, but nothing crazy. More like a few in the hose. No stream like from the pump. I'm going to compression test it in the morning, cold, then hot, look for discrepancies.
Old Dec 27, 2013 | 06:51 AM
carlspeed's Avatar
I'm going to go pull the compression in a few minutes. I think I've only used it for a lawn mower, is there any specific way to pull the compression on this motor? I read somewhere that you're supposed to hold throttle WOT while trying the key?
Old Dec 27, 2013 | 09:31 AM
Gamefreakgc's Avatar
This'll help: http://personal.utulsa.edu/~nathan-b...66compress.pdf
If the compression check comes back clean, go get a pressure check. I had one done for $25 along with an oil change recently. It'll tell you immediately if you have any external leaks. If not, yeah it's your head gasket and not much you can do there.
I suppose if you really want it to last, you could remove the thermostat... but it might cause undesirable side effects like the engine never warming up completely. But if you are ok with that then give it a try. The thermostat is on the engine block at the end of the lower radiator hose.
By the way... is either the top or bottom radiator hose cold after it gets up to operating temperature?
Old Dec 28, 2013 | 07:55 AM
carlspeed's Avatar
Compression from passenger front to back, 150-145-X. Why X? because I couldn't get the compression tester inside the plug hole with all of the stuff in the way there. I did get the compression done on the drivers side. 150-140-140.
Looks like the block is good. Hasn't given me any more problems and I've used it a few times.
Alex Bessinger
Aug 31, 2015 09:17 AM
Logz808
Jul 26, 2015 07:09 AM
Jeffreynmandy
Jul 18, 2015 08:26 AM
Coreyr384
Jul 10, 2015 11:13 AM
