torsion bar kift
Old Dec 30, 2013 | 08:10 AM
cpljenkins01's Avatar
torsion bar kift
I was wondering what everyones thoughts are on cranking your torsion bars up to lift the front end? I have seen people do it before and I know you will need a front end alignment afterward. I would like to add a inch or two lift to the front end to level my truck out.
Old Dec 30, 2013 | 08:15 AM
houston's Avatar
I ran ball joint spacers and cranked torsion a for a while to match my 2" OME leafs, you will differently need to align everything afterwords
Old Dec 30, 2013 | 08:58 AM
RustBucket's Avatar
Spacers would be the better route. Cranked tbars limits travel and makes the ride harsh.
Old Dec 30, 2013 | 01:19 PM
93Xtra-Cab's Avatar
^This. Some people even install spacers and LOOSEN the torsion bar down to stock height in order to get a softer ride.
Old Dec 30, 2013 | 02:53 PM
Laurentian's Avatar
A basic front end set-up is to run a 1.5" in ball joint spacer
with aftermarket torsion bars such as OME or Sway-Away and run
them with very little pre load. This will allow you more wheel travel
as mentioned and with the higher spring rate you can remove
the front sway bar completely. You'll end up about 2" higher in front.
Cranked torsions are horrible and the front end gets skittish on the road,
dangerous stuff.
These are the BJ spacers I will be ordering :
http://www.krfabs.com/product_detail.php?productID=11
Old Dec 30, 2013 | 03:18 PM
dropzone's Avatar
Fossilized
Crank'em up if you are related to a chiropractor
Old Dec 30, 2013 | 03:48 PM
kawasakilewis's Avatar
if you want it to be a pavement princess, crank away, if you want your suspension to actually function, get balljoint spacers, shave your bumpstops slightly, relax the t-bars, and get longer shocks from the front of a samurai.
ladybugRC
458
Aug 21, 2020 10:41 AM
choppe777
May 16, 2016 08:00 AM
A2theK
Oct 14, 2015 07:10 AM
Obmi
Oct 4, 2015 11:30 AM
HiLuxer
Sep 9, 2015 02:43 PM
