3.0 Running rough / No Power after head gasket job
Hope I can get some help. I have a 91 pickup with the 3.0. Just got done doing head gaskets. Started it up, timed it. Replaced timing belt etc. It runs very rough at idle. Low idle ( around 500-600) all new plugs and wires. When I rev it up it just goes dead kinda like a flat spot.
Sprayed all vacuum lines down with carb cleaner, sprayed intake manifolds etc to get check for leaks. No sign of any. No check engine light. No codes.
Checked firing order its good, checked and rechecked all vacuum line routing.
I appreciate the help.
Spicer
Apr 7, 2026 07:17 PM
zd92655
Mar 6, 2022 12:58 PM
voiddweller
19
May 2, 2016 09:10 PM
