3.0 Running rough / No Power after head gasket job
Old Dec 16, 2013 | 06:22 AM
Koso1985's Avatar
Question 3.0 Running rough / No Power after head gasket job
Hope I can get some help. I have a 91 pickup with the 3.0. Just got done doing head gaskets. Started it up, timed it. Replaced timing belt etc. It runs very rough at idle. Low idle ( around 500-600) all new plugs and wires. When I rev it up it just goes dead kinda like a flat spot.
Sprayed all vacuum lines down with carb cleaner, sprayed intake manifolds etc to get check for leaks. No sign of any. No check engine light. No codes.
Checked firing order its good, checked and rechecked all vacuum line routing.
I appreciate the help.
Old Dec 16, 2013 | 07:32 AM
big bear's Avatar
Cam timing dead on ?
What are your valve clearances ?
Old Dec 16, 2013 | 07:55 AM
Koso1985's Avatar
Cam timing is dead on. Have not checked Valve Clearances
Spicer
Apr 7, 2026 07:17 PM
zd92655
Mar 6, 2022 12:58 PM
naward1996
Apr 23, 2018 05:23 PM
voiddweller
19
May 2, 2016 09:10 PM
paxanders
Jun 21, 2015 06:29 AM
