89 v6 no power and idled roughly
Old Dec 17, 2013 | 02:22 PM
Yota 4ever's Avatar
Please help I have replaced all kind of stuff like tps airflow meter new plugs cap and rotor plug wires reset timings timing belt thermostat water pump my codes are 41 and 51 please help
Old Dec 17, 2013 | 02:54 PM
capt 44's Avatar
did you make sure you installed the tps correctly with a volt meter to make sure its in line
Old Dec 17, 2013 | 06:05 PM
ksti's Avatar
The first I would check is to make each and every vacuum line/hose is in its proper place.
Old Dec 17, 2013 | 06:14 PM
Yota 4ever's Avatar
Checked all that with carb cleaner
Old Dec 17, 2013 | 06:23 PM
ksti's Avatar
Ok, code 41= throttle position circuit fault.
As capt 44 said did you set tps with volt meter ?
Here is a link if you need it.
www.4crawler.com/4x4/CheapTricks/TPS/index.shtml
Old Dec 17, 2013 | 07:36 PM
Yota 4ever's Avatar
Thanks but checked it and it's good
Old Dec 17, 2013 | 07:53 PM
longshot454's Avatar
I am tracking down the same thing on my 92 4runner. Im currently testing my VAFM to see if it is bad. But have you tried a known good ECM? might be you need a new computer.
Sleaker
Aug 26, 2020 06:03 AM
Eggslinger
Jun 8, 2019 03:32 PM
montanatruck
Feb 26, 2017 07:07 AM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
