Spits and Sputters
Old Dec 7, 2013 | 09:12 AM
banditbuggy145's Avatar
Spits and Sputters
In the last week my pickup has decided to sputter when under load. It idles like it did before and runs fine until a hill or on the highway. Today I replaced the fuel filter, replaced the distributor cap and rotor and replaced the coil wire(have the rest of them still left to replace but i only had a few hours to work on it). Plugs were replaced last winter. Also have yet to re-check the timing. I ran a bottle of Lucas oil tune up(top end lubricant/fuel injector cleaner) in it to see if that made any difference....nope. I plan on pulling the plugs and checking the timing the next time i work on it but does anyone have any suggestions?? I've been searching on here and looking at my service manual and haven't really found any definite answers. Could it simply be just water in the gas? When it does sputter, it feels exactly like it does right before it runs out of gas so i believe its a fuel issue not an ignition issue. CEL has been on since i bought the truck(think O2 sensors) so i cant really use the codes to determine the new issue. Any help would be great!!
Old Dec 7, 2013 | 12:28 PM
Forgot to mention its a 1995 SR5 pickup with the 3vze
Old Dec 9, 2013 | 06:32 AM
Boyd's Avatar
Same situation
I have the same problem... Except mine is a 1988 3.0
Still looking fur answer of possibilities?
So far I replaced the spark plugs, wire, cap n rotor. Now looking fur thread on how to set the timing fur my truck? If that don't werk... I have no clue!
Old Dec 9, 2013 | 07:24 AM
Ryan G.'s Avatar
check fuel pressure while driving around see if your fuel pressure cuts out under load. Don't just check it sitting in the driveway.
Old Dec 11, 2013 | 05:29 AM
im going to hook an external pump and tank up and stick it in the bed and see if that works. if i have low pressure could it just be the pump or fuel pressure regulator?
Old Dec 17, 2013 | 09:48 AM
Boyd's Avatar
Ok, doing a follow up on my fix here... So I replaced the fuel filter! Now it back to normal!!! Thanks Ryan G!
I asked the guy how bad was the fuel filter? He said he could blow through it!
Old Dec 17, 2013 | 08:19 PM
Ryan G.'s Avatar
glad to help
Gutted91
Jan 3, 2020 09:48 AM
Marley2984
Dec 6, 2015 05:19 AM
Firefightersink15
Nov 23, 2015 10:32 PM
93RedKrawler
Sep 25, 2015 04:03 AM
Gutted91
Sep 17, 2015 05:44 PM
