4wd Problems
Old Dec 15, 2013 | 10:21 AM
Russmoe's Avatar
4wd Problems
I have a 89 p/u 4cyl, manual tranny, manual locking hubs. Since I've owned the truck the 4wd indicator light hasn't worked but 4wd did until today. I have made sure the hubs are locking in and they are. I tried turning the front drive shaft which causes the front wheels to want to turn. I'm just trying to isolate the problem to the front different or transfer case
Old Dec 15, 2013 | 10:23 AM
Russmoe's Avatar
Differential*
Old Dec 15, 2013 | 10:35 AM
Cyberman's Avatar
1. Raise the front end till the wheels are off the ground.
2. Put truck in 2wd, lock hubs.
3. Turn driveshaft, wheels should turn. If not, bad diff, or ADD not engaging (if equipped).
4. Lower front, raise rear tires off ground, or to be safer, remove rear driveshaft.
5. Put truck in 4wd hubs UNLOCKED.
6. Start truck and put in gear. Make sure it doesn't move on you, or have someone else inside with the brakes on.
7. Front drivetrain should spin all the way to the hubs. If not, tcase problems.
Old Dec 15, 2013 | 01:52 PM
Russmoe's Avatar
Narrowed it down to the transfercase not engaging power to the front driveshaft
Old Dec 15, 2013 | 03:26 PM
Cyberman's Avatar
Yikes.
If it is, you'll need to take the transfer out to find out what's up.
Hope it's something easy.
Edit: if you have a chain driven case, let me know. I've got one sitting in my garage.
Old Dec 15, 2013 | 03:33 PM
Russmoe's Avatar
I have been looking for another truck or 4runner for a few months now so I will take this as a push into a another vehicle. The 4wd was the only positive it had going for it, body is gone frame is patched and rotting think its time for the graveyard
Old Dec 15, 2013 | 03:43 PM
Cyberman's Avatar
Don't drive it to a junk yard. Drive it to my house lol.
djpg2000
Nov 11, 2020 04:56 AM
mskalmus
May 28, 2017 07:51 AM
adammtb
Jul 27, 2015 11:57 AM
jgwerth
Jul 16, 2015 03:23 PM
TokyoD23
Jul 12, 2015 06:01 AM
