PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 [82] 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239
  1. 22RE horrible gas mileage
  2. 87-89 pickups
  3. New tires 89 4runner coopers new AT3 all terrain offroad tire (pics
  4. White smoke, weird smell when i turn off car
  5. Bed side/Quarter panel
  6. Diff oil color question.
  7. Pinion Flange nut came loose- possible damage extent.
  8. isr mod
  9. Somewhat newb question regarding new truck
  10. 22re Engines
  11. New mod shopping spree!!
  12. O.b.a. question
  13. Shes Alive
  14. squeaky rearend/undercarridge noise
  15. Just fired it up
  16. Benefits of Exhaust Header??
  17. Ignition switches on different years interchangeable???
  18. 88-89 3VZE ECT Pinout
  19. exhaust sounds
  20. Post-accident restoration questions
  21. Swapping parts from 2nd gen to 3rd
  22. nooob here with a bit of a wiring question!!
  23. Shorting Fuses and wiring help.
  24. What radiator to buy for 88 P/U 4x4 MT?
  25. reasons for bad idle/miss
  26. Where is the voltage regulator on an 86 22R?
  27. '95 3vze way tight valve lash - huh?
  28. early 22r head
  29. help with headlight high beam problem
  30. 31's are rubbing
  31. supra AFM clarification
  32. 22re idle is 'sometimes' fast when hot (1990 4x4)
  33. 1991 Toyota Pickup Clutch Pedal Help
  34. Locking nut on AC dummie pully??
  35. Roof Rack Rails mounted on a 4runner topper
  36. Tranny and Transfer Case levers hitting
  37. Rear Driveshaft compatibility
  38. Toyota Pickup Fuel Tank
  39. Auxiliary fuel tank for 1st Gen 4runner
  40. 22r radiator building boost
  41. Photo help needed
  42. o2 sensor male plug
  43. Clutch....
  44. Heater Control Issues
  45. AC expansion valve adapter issues
  46. Price of Toyota Red coolant
  47. 22r Timing chain replacement
  48. Rear leaf spring greasable bolt size
  49. Starter issues
  50. Stalling an automatic 22RE
  51. Need Help Passing DEQ
  52. 3VZE rough idle
  53. TPS issue..
  54. power steering line
  55. V6 Upgrades/Interchanges from 22RE
  56. Oil pressure vs. Oil viscosity Question?
  57. Wiring help needed for O2 sensor
  58. 94 P/U 22re stumbling accel, poor fuel mileage
  59. Charred fuel pump plug!!!??
  60. 1988 22R-E Help. Ran great up till now. Lacks low end torque/ rough idle.
  61. 4.10 Gears & 35x.12.5?
  62. Leaking Rear Differential (with picture)
  63. Maglite Holder Pic
  64. 3.0L 3VZE head rebuild advice
  65. 88 Pickup Rear Driveshaft
  66. Water Leak in '94 4Runner
  67. 89 4runner for my first vehicle
  68. Bad vibration from rear
  69. 20r exhaust manifold
  70. Quick 4runner tailgate question
  71. 1986 single cab transplanted on a 1985 4runner frame?
  72. 22RE has several issues....any suggestions?
  73. 86 22R Newly Rebuilt Engine, Low Idle/Stall First start up
  74. Axle change a breeze & other myths & legends
  75. safari snorkel ?
  76. Can Coolant go bad in storage?
  77. ? Adjustment screw on efi
  78. 33's with stock suspension.
  79. Faulty chain tensioner?
  80. 1987 4runner idle problems
  81. 1988 22re spark plug / oil help
  82. Head gasket, cracked block, or other?!?!
  83. engine overheating
  84. Sunroof on 1986 extra cab
  85. Starter not engaging?
  86. Rear crank bearing cap
  87. 2 piece to 1 driveline swap advise please.
  88. 87 4runner ac ?
  89. overheating when using heater only?
  90. one piece stock front bumper
  91. Alternator wiring problems
  92. waterpump, fan clutch, thermostat, radiator
  93. Question About torsion Bars
  94. Performance issues - related to timing?
  95. Air Ducts
  96. 1990 22re running issues
  97. Roof racks make a difference in MPG!
  98. Obsolete Seal retainer gasket?
  99. Rotor removal
  100. LC Coil/BJ Spacer Lift Finally On!
  101. 1988 Toyota 4Runner Starter Issue
  102. A340 going crazy
  103. Transmission trouble.
  104. Need Help Installing New 3vze
  105. Clunking, knocking somewhere back there
  106. 22r auto - low idle when in gear
  107. 94 Pickup Knock Sensor Pigtail Ground
  108. Duracool, anyone make the switch?
  109. Do OEM Toyota timing components have any branding on them?
  110. Replacement 2nd Gen 4runner quarters
  111. Remove 22RE Head With Manifolds Attached?
  112. smittybilt rear on a 2nd gen 4runner
  113. Failed smog, crummy performance
  114. Coolant in my oil
  115. '86 22R Auto - Rough and late shifting
  116. Rear bumper that works with body lift
  117. Mysterious Current Draw
  118. My Wonderfull '86 4Runner!!!
  119. 93' sr5 4x4 axle seal keeps leaking
  120. Looking for 22re info for a build.
  121. Rear wheel bearing play cause of vibration? (video)
  122. Got a new 4runner!! lots of pics
  123. Cannot remove 3rd member (spot welded?)
  124. Quickie Head Gasket Job Tips?
  125. Metallic rattle
  126. tranny install problem! Need lots of help!
  127. Coolant Leak Metal Pipe
  128. EGR totally dead?
  129. 87 4runner build FINALLY STARTING
  130. Does this timing cover look wrecked to you? [Pics]
  131. truck is sluggish and sometimes stutters at lower rpms
  132. W-56 perfect rebuild pics
  133. Slow to start
  134. 22r engine rebuild question
  135. 87 4runner 22re running rich
  136. Quick question on these exhaust bolts....
  137. Injector wiring on 22RE
  138. 88 4runner Rear Heater Help
  139. AC evaporator connection problem
  140. Slurping noise? Video inside!
  141. massive oil leak front of head
  142. Strange power drain problems.
  143. Fuel Circuit opening relay location?
  144. '90 4runner running issues
  145. 88 3.0 auto CLUNKING noise
  146. '88 4runner factory hitch install help
  147. 1st Gen 4Runner Top Storage - Will this hurt my topper?
  148. transfercase bolt torque
  149. What is this air intake hose?
  150. Top radiator hose housing
  151. weird brake issue
  152. 92 toyota maf problem
  153. Who Sells New Throttle Cables?
  154. Heater/Fan issues.
  155. AC button lights up, compressor intermittently works - bad connection expected
  156. Help don't know why my suspension is horrible?
  157. Brass door hinge bushings?
  158. Need help disabling specific fuel injectors...
  159. 22re Smoking in my 89 4runner
  160. Truck Just Started Missing
  161. fender flares
  162. 22ret - which vacuum lines can I get rid of?
  163. Transmission problems
  164. Crazy ideas about pickup vs 4runner suspensions
  165. Window is Wack! any pointers..?
  166. Mystery Leak 3VZE Questions
  167. hesitation during acceleration
  168. Getting more horsepower?
  169. 3L V6 Starter Solenoid Repair
  170. replacing carpet with anti-fatigue mat
  171. Local Toyota dealership offers remanufactured clutch and pressure plate only?
  172. Swaybar delete = lean?
  173. A little Help Here Leaking Coolant
  174. Clocked T-Case Adapter now stuck in 2H
  175. 2nd gen 4cyl 4runner
  176. Rear spring pad placement???
  177. 22re wiring + cranking problems
  178. '88 floor pan questions
  179. factory diff and ifs with 4.88 fit pickup?
  180. Backing Plate Eliminators...pros and cons????
  181. No start after mudding
  182. Tach for 88 and 94 PU?
  183. truck sounds like a mini deisel!
  184. non cali 22re into cali truck
  185. Should i do a new engine, re-gear, or let the old Yota go...
  186. A/C and starting issues
  187. Problems starting after engine swap
  188. 1986 toyota turbo efi
  189. 95 4Runner - cut out on I-state, now won't crank
  190. 1st Gen Runner E Locker questions
  191. Using duck tape and bailing wire to fix a fuel pump
  192. 93 pickup 3.0 timing
  193. Smog issue
  194. Fluctuating oil psi
  195. U Joint size 95 PU 4x4?
  196. i need some help figuring out if this is really a spun rod bearing
  197. opinions on lift kit (brand, ride, etc..)
  198. Intermittent start problem
  199. 22re motor
  200. Knock sensor removal procedure?
  201. Replace rear coils or put in "air bags"
  202. Yet another Rear window problem... but this one's different! Kinda
  203. installed wrong part no. timing belt (pics)
  204. Blue box?
  205. 90 4runner 22re to 22r: Hesitation/Bogging
  206. Trouble shifting while wheeling
  207. 94 pickup 22re knock sensor
  208. Off-Road Lighting Woes - Switch and Fuse Issues
  209. 22RE Engine Dress Up
  210. 1984 Nissan 720 on 1988 4Runner frame. Ever been done before??
  211. About to purchase shocks for my LC/BJ Lift
  212. 3VZE Power at low RPM
  213. 86 Runner rear window won't work anymore.
  214. My first 22RE swap (pics/vid)
  215. My New Gears. Help Me Read Paint? Thanks.
  216. 94 3vze ext cab NO BRAKES
  217. CEL CODE 71 EGR or Modulator?
  218. 85 yota 22re fit in 92 yota 22re????? HELP
  219. Need Help getting lower ball joint back in ASAP!!!
  220. timing cover plate
  221. Worth the swap? (Leaf springs from 87 Pickup to 88 4runner)
  222. 88 22re help!!! :(
  223. Bushings for front 3rd frame mounts
  224. Cheap ways to replace a headliner
  225. 190 hp 3.0 V-6 from CHS Machine 210 Torq
  226. I have low 4 with out 4wd
  227. Painting my top
  228. 3.0L owners
  229. driveline vibration question
  230. What does this temp sensor do?
  231. My 88 keeps killing fuel pumps!?!?
  232. TPS and high idle?
  233. 1992 4Runner A/C Port Schrader Valve?
  234. ADD reverse question
  235. ZUK Mod still rides stiff!
  236. 87 Truck backfires, surges, and sputters
  237. New Toyota!
  238. 89 rough idle and acting like it's lost power
  239. 22re need help
  240. I think my Transfer Case is shot
  241. What is needed for injector pulse
  242. 1988 PU 22RE won't start. Has gas, has spark, turns over,wont fire. Ran yesterday?!
  243. Advice to make her a safer ride?
  244. electrical help
  245. Bypassing Rear Window Wiring, Headed Straight to Battery
  246. AFM question
  247. sr5 gauge cluster problems
  248. what does this code for mycheck engine light mean?
  249. 87 4runner Problems
  250. gonna do the 3.4 swap
