Stock height?
Old Nov 27, 2012 | 01:29 PM
caminochaos's Avatar
Stock height?
What is the stock ride height for my 1989 p/u 4x4 xtra cab.
Old Nov 27, 2012 | 01:50 PM
Nvm...61.4" total height per ehow.com. Does this sound right?
Old Nov 27, 2012 | 03:12 PM
rworegon's Avatar
It depends on what tires are on there, does it not?
Old Nov 27, 2012 | 04:23 PM
NickMiller's Avatar
Not if you measure from the middle of the hub to the fender... Only the suspension affects that measurement.
Old Nov 27, 2012 | 04:28 PM
rworegon's Avatar
Nich, OP tossed out 61.4" which would seem to be ground to top of cab, not the measurement you suggest.
Old Nov 28, 2012 | 05:59 AM
scope103's Avatar
ehow.com? Are you kidding? Have you ever read any of their articles?
Uh, true, but then it would depend on whether the fender was tweaked, and you can't set "ride height" that way.
"Ride Height" is called "Chassis Ground Clearance" in the manual. http://personal.utulsa.edu/~nathan-b...axle/3-2wd.pdf And yes, it depends on tire size and model. http://personal.utulsa.edu/~nathan-b...17suspensi.pdf (This page is for a '93 so it won't do you any good -- it's just to demonstrate that you need to know a lot more than you've told us.)
punks_is_4x4
May 31, 2016 06:03 AM
Williamemslie
14
Oct 5, 2015 09:28 AM
_Nicco_
Sep 21, 2015 03:06 PM
JHalcyonM
Sep 14, 2015 01:10 AM
DiggnDeep
Sep 3, 2015 02:45 PM
