R151f tranny for 87 4runner
Old Nov 19, 2012 | 06:00 AM
bmxmike's Avatar
I wanna put a marlin built r151f tranny in my 87 4runner...i wanna know for 100% if it will bolt right up and be good to go...i have a regular 22re...has anyone done it or know if ill be good
Old Nov 19, 2012 | 06:50 AM
TNRabbit's Avatar
R151F
A 4WD transmission found in only two model years of Toyota trucks(not available in 4runners). [Turbo 22-RTE 1986 and 1987] Also 1KZ-TE Prado Landcruiser 9?-96. (also in 1KZ/T Hilux Surfs 93-95)
Ratios:
First Gear: 4.313:1
Second Gear: 2.330:1
Third Gear: 1.436:1
Fourth Gear: 1.00:1
Fifth Gear: 0.836:1
Old Nov 19, 2012 | 07:47 AM
bmxmike's Avatar
Yea i knew that but i wanna swap it in with my non turbo motor...would it work as i said i wanna be 100% sure bc i dont wanna have it shipped to my house and go to put it in and it doesnt fit lol
Old Nov 19, 2012 | 08:40 AM
arlindsay1992's Avatar
The RE and RTE both use the same block so it will bolt up fine to the motor. However, I think the RTE used a different clutch. The clutch in your truck may or may not work with that trans.
Old Nov 19, 2012 | 06:55 PM
Turd Furgeson's Avatar
Yeah I think you need the 22rte specific clutch. But I think 92 and up 22re works too.
Old Nov 19, 2012 | 07:52 PM
TrikeKid's Avatar
Clutch disk size is the difference in the turbo clutch, the rest is the same. The turbo clutch and flywheel are a great upgrade for any 4 banger truck. The output on the 151F is 23 spline to your stock case's 21, so you'll need to swap in another input gear or find a turbo case to swap in with the new trans. Swapping to 23 spline 4.7 gears in your case would be an option as well.
mskalmus
May 28, 2017 07:51 AM
BeMiceElf
Oct 10, 2015 09:40 PM
Iceman4193
Jul 15, 2015 04:48 PM
madxman21
Jul 9, 2015 10:26 AM
Jnkml
Jul 6, 2015 01:20 PM
