What is that little plunger thing ...
Old Nov 12, 2012 | 04:52 AM
cvs334's Avatar
that the throttle arm bottoms out on?
to be clear the throttle cable attaches to this arm and there is an allen screw that i though was a stop, but it depresses a little do da, that does not seem to have a function.
is this just to dampen the throttle closing?
Old Nov 12, 2012 | 05:32 AM
Marc's Avatar
Yes, it sounds like the throttle damper that you're talking about.
Although a picture would confirm it.
Old Nov 12, 2012 | 05:51 AM
MudHippy's Avatar
Throttle damper?
It's called a dash pot...
Old Nov 12, 2012 | 06:11 AM
scope103's Avatar
Actually, there are two (at least!) "little plunger things."
In the foreground of the picture is the "Dashpot", which does damp (not dampen) the throttle closing (both you and MudHippy are correct). If the throttle slams shut, the fuel left in the intake has no air to burn, so you get a fireball out the exhaust. Or at least a high-HC puff.
The one in the back is the throttle opener. When the vacuum goes to zero, the throttle is opened a crack. I believe this is to reduce dieseling.
The manual is a terrific resource: http://personal.utulsa.edu/~nathan-b...93throttle.pdf
dumpster84
Apr 30, 2016 06:03 AM
garagespace
Oct 11, 2015 10:59 AM
exporunner
3.4 Swaps
Aug 3, 2015 06:10 PM
v_man
Jul 23, 2015 04:01 PM
1996Taco
Jul 20, 2015 12:02 AM
