initial start checklist??
Old Nov 13, 2012 | 02:38 PM
bensyota's Avatar
Pulled my 3.0 out to replace every gasket, seal and valve there is and adjusted valves. What precautions should I take when I do the initial startup so everything goes smooth? Thank you.
Old Nov 13, 2012 | 05:05 PM
scope103's Avatar
use the FP to B+ jumper to run the fuel pump and verify you have no fuel leaks.
Gently rotate the crank with a wrench to feel for any uneven spots.
Set up a timing light when you first crank it, to quickly check that the timing is somewhere in the ball park (it has to warm up to actually set it).
Old Nov 13, 2012 | 06:32 PM
bensyota's Avatar
cool. i actually had to do that to find out the fuel pressure dampner was leaking. got it on the fuel priming. what about oil. i read to pull dist coil wire and ground and crank it over a few times to get oil pumping??? would this be correct?
Doug4320
Mar 24, 2018 10:11 PM
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
raiderhawks00
Jul 8, 2015 06:23 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
