initial start checklist??
Pulled my 3.0 out to replace every gasket, seal and valve there is and adjusted valves. What precautions should I take when I do the initial startup so everything goes smooth? Thank you.
use the FP to B+ jumper to run the fuel pump and verify you have no fuel leaks.
Gently rotate the crank with a wrench to feel for any uneven spots.
Set up a timing light when you first crank it, to quickly check that the timing is somewhere in the ball park (it has to warm up to actually set it).
cool. i actually had to do that to find out the fuel pressure dampner was leaking. got it on the fuel priming. what about oil. i read to pull dist coil wire and ground and crank it over a few times to get oil pumping??? would this be correct?
ZONAYODA
Jul 13, 2015 07:17 PM
Poncho0206
Jul 10, 2015 06:21 PM
