PDA
View Full Version : 86-95 Trucks & 4Runners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 [225] 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267
  1. easy t-bar adjustmeny project... NOT
  2. A/C Problem
  3. squeeky noises
  4. Pull 3vze with r without transmission?
  5. Check Out This 4 Runner!
  6. Lets see all the best 2nd gen 4Runners now
  7. One hub locked, one unlocked
  8. Discovered rust / Repair questions
  9. finished painting
  10. my new wheels
  11. sold my baby....
  12. Can't get my seat to slide forward?
  13. 3VZE engine parts! What you need?
  14. need quick help
  15. 86 sr5 turbo help!
  16. Possibility of swap....'86 4nr to '87 4rnr
  17. '86 4cylinder to 6cylinder conversion?
  18. hmmwv's cab swap
  19. Sad day today
  20. just finished my clutch install and have a few questions
  21. Royal Purple oil
  22. 22RE Code 71
  23. front corner panel
  24. Newb wondering about a driveshaft switcheroo
  25. Can i please see your rear......
  26. What are these holes on my new third member?
  27. alternator?
  28. help... 1995 limited sr5 4runner
  29. Replacing Fuel Filter
  30. What is this combo worth?
  31. PAIR valve gasket - Can I use FIPG instead?
  32. 16" Rim to Fender after BJ Spacers
  33. Need pics of 33x10.5 on stock runner
  34. 22re engine knock
  35. stupid clamp together exhaust
  36. Does anyone's elses hood feel like it's gonna flip up.
  37. cleaning out the inside of a frame
  38. 1st Gen SR5 gauge swap problems...
  39. Error code 52!!!???
  40. Clunk while backing up
  41. Fuel Injector plug question please...
  42. pics
  43. Car seat in an 88 4runner??
  44. no back brakes
  45. Another worn key/ignition cylinder...
  46. Run'n Rough
  47. Rolled my truck...
  48. Got some new shoes.....
  49. new side exhaust through bedside
  50. 86 runner rear bumper on a 94 p/u?
  51. 3.0 Auto in Low Range when H2 selected?
  52. Need help in southern indiana
  53. Rancho rear springs, looking for info on them
  54. Lakewood gear oil?
  55. '88 22R ticking
  56. need help B4 paint!
  57. What / how to clean the inside of bell housing & back of motor?
  58. 89 floors get hot--help!
  59. Measurement for IFS Truss
  60. Where is the No. 5 water by-pass hose??
  61. 4.3 swap
  62. Unsolved injector mystery
  63. 87 4Runner Air conditioner not working
  64. Rebuilding IFS - The Story
  65. Idle Problems When Cold
  66. Started on Sliders
  67. who has a long travel kit
  68. Sway Bar Disconnects, Ideas?
  69. can Coil-Over shocks be put on the front of a 2nd gen 4Runner?
  70. in the middle of replacing clutch
  71. Sway Bars Bushing Size??
  72. 89 4runner dash and auto shift light problem
  73. What is this part called???????
  74. what gears should I run?
  75. Frame Restoration.
  76. CA smog test only victim.....
  77. 86 Runner A/C
  78. trouble wiring up a 22re in a 3.0 4runner
  79. what can i use to clean preped bare metal
  80. power steering fluid leak(anyone heard about this recall?)
  81. 85 tube doors on a 94 p/u will they work?
  82. are my leafs worn out???
  83. are my leafs worn out???
  84. cam,valve,spring setup what do you think?
  85. What is YotaTechs nicest 86-89 4Runner?? Post the best!!
  86. OEM vs. Store brand seals & bearings - Does it matter???
  87. Vf signal
  88. Lightbar and Lights w/ PICS!!!
  89. Going for my 3rd Remanuf. P/S pump.
  90. Idle problem fixed thanks to you guys
  91. Man...I need help, or advice...I need direction with this
  92. ****ards bent my backing plates
  93. 90 4runner alternator
  94. question about coil spacers and road handling
  95. Looking at a 95 4runner
  96. Why do I have gas in my intake chamber??
  97. Very low idle with AC on
  98. gear swap
  99. Front Axle Questions
  100. 94 4runner worth??? im clueless.
  101. 4runner CEL
  102. Need help identifying part...
  103. Front breather in IFS
  104. 4x4 4runner parts on 2wd truck? multiple questions.
  105. temp sensor going nuts
  106. looking at 94 runner - what is fair for this one?
  107. need hitch advice
  108. not sure what to do
  109. Oil Pressure Gauge Does Not Work
  110. 22re idle
  111. flowmaster 70 series??
  112. What happens if your valve clearance is too big?
  113. No More running boards
  114. funny speedo
  115. replacing my clutch
  116. radio problem...help
  117. Loose/Broken antenna fix
  118. Clutch parts advice, what brand parts to use???
  119. Diagonose My 4Runner Video
  120. Argh, clunking, knocking engine
  121. Shredded Clutch disk?
  122. I need a new motor!
  123. Diagonose My 4Runner Video
  124. Rod ends Where to buy.
  125. A bit of a klunk when turning full lock to lock
  126. Mizumoauto: Good, Bad, Any experince?
  127. How can I test injector wiring harness
  128. headrest questions
  129. need advice on my first 4x4 yota.
  130. 02 sensor help
  131. Long Travel Parts
  132. what options do i have to lift rear 5 inches
  133. check engine light on
  134. Rebuild - help
  135. Only on Ebay
  136. Black Smoke + Misfiring
  137. ABS LIGHT problem
  138. What did I do what did I do!!!
  139. Tranny problem
  140. Does this look normal or excesive? (drain plug shavings)
  141. Newer Toyota truck wheels on old 4Runner
  142. My $65 4Runner Bikini Top
  143. Rear Disc Brakes -opinions
  144. 22re - great hwy milage, horrible city mileage
  145. Injector seals
  146. Body Swap
  147. 4x4 with no rear?
  148. Result after the 5 Speed Swap and MLS HG Repair
  149. 22-R head swap???
  150. totally built up 2nd gen 4runner F/S in WA
  151. 3.0 smoking bad at startup...oil?
  152. Welded on Lightbar :)
  153. Bad vibes after 4Runner lift & rear leaf spring swap
  154. checking auto hubs
  155. 95 4Runner steering wheel shaking BAD!
  156. Y-pipe mod: my turn
  157. Master Cylinder Gasket?
  158. 2 issues with the 5speed tranny
  159. Wanted: 86 4Runner Power Window Stuff
  160. Questions on rebuilding a 22re
  161. Probably should change the valve adjusters, too, huh?
  162. AHHHHHHHH! 88 pickup 22re Coolant on the passanger floor...
  163. What is this and what is it for??
  164. HOT after long trip inside truck!?
  165. 4wd will not engage
  166. A/C Techs Help Needed
  167. Post Your Pics!!!
  168. rebuilding 87 4runner transfer case
  169. week off work, and new leaks...and weird alt.
  170. sas info
  171. Definitive answer to setting valve clearances, hot vs. cold.
  172. Candle Wax and Pilot Bearing
  173. HELP! 1994 4Runner Power Steering & Distributor fit 1993 Pickup?
  174. Need Help From People Running Ct26 Turbos
  175. How much backpressure should I have?
  176. 4runner jerks when headlights are turned on
  177. Adjusting MAF
  178. 4" lift... best size tire?
  179. Wierd LED on 92 4WD P/U dash
  180. 86 auto tranny slipping?
  181. Anyone have FSM for 94 4Runner Digitized?
  182. used 2nd gen torsion bars any resale value?
  183. symptoms of a bad motor/trans mount
  184. Cleaning tops of pistons & block before heads...
  185. Diesel conversion: Auto or 5spd?
  186. 1992 4runner AC change over
  187. no power and rough idle when raining
  188. cold air filter
  189. OME lift what tire and rim?
  190. Knock Sensor Code 12 could this be caused by valve train lifter noise being to loud
  191. Tundra V8 into '91 Pick Up
  192. 1993 pickup truck 3rd gear grind
  193. I'm gonna kill my 4Runner.....again
  194. Transfer case woes...
  195. So I was under my truck today....
  196. Hesitation to Steer in 4WD
  197. Another 3vze problem thread
  198. Moist And My Pickup ,perform Better ,why??
  199. have some temp issues.
  200. valve cover baffles
  201. Good newbie starter thread...
  202. bucket seat swap...can't find an answer
  203. wet burning dog smell in A/C
  204. squeeky turning
  205. Need immediate help guys!!!!
  206. Vac acc. elimination help
  207. exhaust
  208. Pics of my truck in summer gear
  209. stupid pilot bearing
  210. quick ? bolt size.
  211. cam selection for 22RE
  212. 3.0 Idle/Timing problems, have searched.
  213. New Speakers in 95 runner
  214. Anyone have problems with the new HG since the recall?
  215. Parting out 86 4Runner
  216. 89 offset
  217. Miss in rig untill warmed up....
  218. Change Starter
  219. Diesel 5.9L swap DONE!
  220. where to go for a rebuild
  221. safe to run with speedometer cable unplugged?
  222. 94 p/u A/C problems
  223. 94 runner 4wd ?
  224. emissions?
  225. 89-95 front suspension
  226. Anyone have a 22re in Michigan for sale?
  227. 1992 3.0 starting troubles
  228. Rolled on paint update
  229. Security Cover for back area of 1st Gen
  230. Finally put my Intro Together...X-Post
  231. YEAH A NEW FORUM TOY!!!!! Inserting a YouTube Video within a post.
  232. Help lifting a 86 4runner
  233. Spedo and Tach way off, almost got me in trouble!
  234. 2.7L Swap... What do you think.
  235. 3VZE differences???
  236. Gearing Question
  237. Trans swap/backup lights/cruise control
  238. Shifter Help!
  239. help!! squeaky springs.
  240. Gear lube question
  241. 86 RUnner for sale
  242. Headers, 3.0, do you have to have a lift?
  243. Everyone is going to hate me :(
  244. what would you pay for my complete I.F.S
  245. Sunroof rattle
  246. AC noise and driving question
  247. R&R'ing clutch. What else to do while there?
  248. CV Joints, Bad?
  249. Rebuild or donor engine for 22RE?
  250. Oxigan sensor
