What is this part called???????
Old Jul 12, 2007 | 07:45 AM
kcrunner's Avatar
Old Jul 12, 2007 | 07:47 AM
DeathCougar's Avatar
AC idle up switch.
Old Jul 12, 2007 | 07:48 AM
dont know for 100% what toyota calls it, but its the part that idles up the truck, and can adjust the idle speed of when it idles up.
Old Jul 12, 2007 | 07:53 AM
kcrunner's Avatar
I knew it was for AC idle up, but when I called the dealer's service dept. they said....uh.....not sure what your talking about. And they had a picture of it right in front of them. They called it an Auxilary Air Valve, and wanted $220 for it. Yikes!
I'm trying to figure out if I can order just the white plastic screw, or do I have to order the complete assembly?
So I just need to know the exact name for the part so I can order it.
Thanks fellas!
Old Jul 12, 2007 | 07:59 AM
im sure you cant just order the screw. However, any wrecking yard should have it, as it fits almost any Toyota up to 95 or so.
Old Jul 12, 2007 | 08:01 AM
kcrunner's Avatar
Of course you can't, that would be easy. I searched a couple of wrecking yards and didn't have any luck. But I guess I'll keep at it until I find one, or figure out what it's called.
It's not the flux capacitor, is it?
Old Jul 12, 2007 | 08:32 AM
PirateFins's Avatar
FSM calls it an "Actuator" http://personal.utulsa.edu/~nathan-b...24vacuumsw.pdf
Old Jul 12, 2007 | 08:48 AM
kcrunner's Avatar
Originally Posted by PirateFins
Good diagram, thanks.
Well, actuator sounded pretty good to me, but, Oreilly's didn't know what it was. I'll try the dealer to see if they know anything. Then it's off to my favorite place in the world.......treasure hunting in the salvage yard!
Old Jul 12, 2007 | 11:01 AM
DaveInDenver's Avatar
I think you might have your answer already. But FWIW, I thought the Aux Air Valve is the part under the throttle body that works like a choke. It's got the two coolant lines feeding into it.
http://personal.utulsa.edu/~nathan-b...35auxiliar.pdf
Old Jul 12, 2007 | 11:16 AM
ssupercoolss's Avatar
yup, thats not the aux air valve. but that is an easy part to get off of ebay. search for "22re"
smthwsn357
May 1, 2024 07:28 AM
Iceman4193
Jul 15, 2015 04:48 PM
Steven.m.paulk
Jul 13, 2015 01:40 PM
AaronM
Jul 8, 2015 07:15 PM
