Very low idle with AC on
Old Jul 11, 2007 | 04:42 AM
kcrunner's Avatar
On my 22RE, I have a really low idle when the AC is on. I noticed on my intake that there is a spring with a white plunger in it (sorry, no pics) and that's broken. I figured it has something to do with the idle speed while the AC is on. I realize w/o pics it may be difficult to diagnose this problem, but we'll try anyway.
Old Jul 11, 2007 | 08:13 PM
TC22RE's Avatar
Without pictures it is kind of hard to say, but if i remember correctly, on the side of your intake (the side with all the vacuum hoses on) about in the middle there should be a piece with about 4 vacuum lines attached to it, 2 small, 2 large, and on top of it should be a plastic screw w/ spring. It controlls the idle-up when the AC is turned on. If its broken then you'll need to get it replaced for your ac idle-up to work... hope this helps... I would take a picture of mine for you but its dark and raining outside. Best of luck!
Ok... Found a picture and circled the part. Your part color may vary...
Old Jul 12, 2007 | 06:03 AM
kcrunner's Avatar
That's it. The plunger inside the spring is broken. Wish I knew what this part was called, would make ordering the part easier.
Thanks.
Sleaker
Aug 26, 2020 06:03 AM
Sidherish
Aug 2, 2015 01:42 PM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
